I have a lexmark X4650 and have no manual cannot figure out how to change the ink cartridge.
5 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Posted on Nov 20, 2008
  • 413 Answers
SOURCE: Lexmark x4650 says "print cartridge missing" but just replaced.
CLick on Start, printers and faxes, right click on your printer icon, click on properties.
There should be a tick box to allow you to reset the cartridges to new....
Posted on Jul 02, 2009
Icebassman 5
  • 57 Answers
SOURCE: how do I change the ink cartridge on my lexamark
Hi there.
You open the lid on the front/top of the printer.
Then the printer will set up the print head with the cartridges in the middle. There are white plastic clips on front of each cartridge, pull them gently towards you and the cartridge moves slightly up or you will have to pull it up. To put the new one is you must first take all the wrapping off the cartridge and twist the orange lid off the bottom of the cartridge. Make sure you put the right one in the right place. Push them gently down until you hear a "click" close the lid on the printer and carry on printing.
Iceman.
Posted on Nov 10, 2009
jas247
  • 844 Answers
SOURCE: lexmark X4650 needs new ink cartridges but I've
Welcome to FixYa!
1. Make sure the printer is on.
2. Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.jas247_10.png
4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Thank you for using FixYa!
Keep me posted!
Jas247
Posted on Mar 30, 2011
We put a new color ink cartridge in our lexmark x4650 printer. The colors are not printing correctly. No green, blue.
Try cleaning the mating surfaces of the cartridges with rubbing alchohol on a cue tip. If the printer was out of ink for a while the ink dries on the surface.
Sep 25, 2011 | Lexmark X4650 InkJet Printer
I am having to install a new black cartridge in a Lexmark x4650 printer. I dont know how to get to the ink cartridges installed.I would like for some one to help me with this. I cannot figure out how to...
sagar1111.jpgHere you will see both catriges if your printer is powered on and you open the cover, the cartriges would come to center position automatically,here you will see a half rounded circle at top,
give it a little push towords down and it will be in you hand and while fixing place the cartrige inside and push it slightly.
Mar 23, 2011 | Lexmark X4650 InkJet Printer
Trying to print. gets to 7% and stops. Ink cartridges show question marks. For Lexmark X4650
remove the cartridge and clean all the contact points on it (not the ink spitting part) and reinsrt it. Use a q-tip and rubbing alcohol.
Mar 08, 2011 | Lexmark X4650 InkJet Printer
How do I change the ink cartridge?
http://www.lexmark.com/publications/pdfs/2007/4650/LXDTuser_en.pdf
The above has maintenance procedures for changing the ink jet cartridges and aligning them starting on P. 95.
Jan 08, 2011 | Lexmark X4650 InkJet Printer
How do i change ink cartridges
Hello i hope u 'll be fine.... thanks for using fixya.
Probably
Lexmark X4650 InkJet Printer User Guide will be able to guide you. If you have already installed the Lexmark software on your system you can view the User Guide by going to the Start menu >> Programs >> Lexmark X4600 Series >> User Guide. Scroll to page 94 for instructions on how to install the ink cartridge. If not, you can download it for free from here
User Guide is in pdf format if you have no Adobe Reader software which support .pdf files then Download it from here Adobe Reader
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source.With the cover open,hold the solid white strip and gently slide the carrier to the middle of the printer.Remove the used cartridges. Load the new cartridges.Close the cover.Plug the printer back to power source.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Lexmark X4650 InkJet Printer
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
Lexmark x4650 cartridge problem
maybe your ink is empty. you need to change you cartridge
Feb 25, 2010 | Lexmark X4650 InkJet Printer
How do I change the ink cartridge on my lexamark x4650
Hi there.
Iceman.
Nov 10, 2009 | Lexmark X4650 InkJet Printer
Jul 01, 2009 | Lexmark X4650 InkJet Printer
jasbo
jasbo
