Question about E-Machines eMachines Desktop PC
Pc cooling fans operate but pc will not operate .replaced power supply but still doesn't work.
    Sergeant:
    Champion:
  • 232 Answers
Hi , you may have lost your hard drive or your motherboard .
Posted on Jul 14, 2010
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
Fan stopped working
Power supplies are not meant to be fixed. If you have electronics repair experience, crack it open and replace the fan with a new pc cooling fan of the same size and power.
May 06, 2013 | Antec AR300 300-Watt Power Supply
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
My computer hangs/stop responding expectedly and when i check the processor , it very hot , !!! help me plz ...!!!
You can try to disasseble your desktop and check if the processor fan is not working properly. Try to clean accumulated dust and replace it if needed. Also add more fans to decrease temperature inside the system. Do not operate your desktop as possible, it may do further damage to other components of the system.
Hope this helps.
Aug 28, 2011 | Dell OptiPlex GX270 PC Desktop
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
I havd a Dell Dimension 8200 that sometimes shuts down and power light turns yellow. I can usally open case and plug and on plug to get it to power back up. Recently replaced fans due to fan failure....
Thank for the detail, it really helps...
Most people forget about the power supply. If the power supply overheats, it will shutdown. When shutdown, it will cool off then operate again.
A power supply goes by WATT ratings, the average size power supply is now 450 watts for an average system and should cost around $60.
good luck and don't forget to vote.
Oct 12, 2010 | Dell Dimension 8200 PC Desktop
The cooling fan does not spin.
If that is the only thing that isn't working then the fan itself might just need to be replaced, if you take the make and model of the pc to any computer repair shop they should be able to get you a replacement fan for not much of a cost. They are really easy to change too,fyi.
Apr 07, 2010 | Toshiba (K000016310) Cooling Fan
Cooling Fans compatible with Toshiba A15 laptop
You can't replace the fan, you have to replace the power supply. In order to find out whih one you need the best thing to do is open your PC and find out the Wattage. It will be marked on the outside of your power supply. Just in case you do not know where the power supply is, if yo see where the vents are on your computer the power supply is there. It has a fan to blow the hot air out of it..
Don't forget to rate this solution with four stars before you log out.
Jan 23, 2009 | Antec TriCool 3.125" LED CPU Cooling Fan -...
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
Hp pavillion dv6262eu=====dv6000 underneath also ,,,, has been away for repairs 3 times now in 12 months cooling fan runs at half speed whist operating at all times is...
Most likely a power supply problem. Your power supply is probably going bad or not powerful enough for your system. Swap it out for a known working power supply with enough power for your system. Also make sure there is not excessive dust and dirt on the fans.
May 09, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
