I have a hoover nextra washer dryer model hnwl3126-80 I stopped using the dryer function 6months ago as it has started making a clunking noise. 2 weeks ago the same noise started when my washer was spinning. Yesterday i loaded up and took the kids to school got back home to a very strong rubber /electrical smell opened washer door and smoke escaped out of the top the clothes were damp and the powder had been used but clothes still dirty and smell of this burning smell. I have removed the back of the washer dryer and cannot see any visible problems. Any help or pointers would be greatly appreciated as I canty afford a new one.
  • 9 Answers
SOURCE: Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Posted on Sep 14, 2007
  • 1314 Answers
SOURCE: Kenmore (Whirlpool) washer 110.20912 991 made banging noise at end of spin cycle. Now it wont spin at all.
i need to chat with you email me at b4829@yahoo.com need more info
Posted on Jan 01, 2008
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
SOURCE: programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Posted on Jun 01, 2009
  • 574 Answers
SOURCE: hoover nextra washing machine , not draining
take pump off and take apart to clean
Posted on Aug 28, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
User manual for hoover nextra tumble dryer
I have a Hoover Nextra washer/dryer machine. It has been working fine but 2 days ago it stopped taking water into the drum. When I put the machine on, I can hear water running into it and the water does go into the powder compartment and clears that. However, only a tiny bit of water is getting into the drum of the machine.
In case it is relevant, there is only one hose at the back, not 2 hoses like some machines have. I don't think it can be water pressure as it has always worked before.
I hope someone can maybe give an idea as to how to fix it as I have toddlers and need it fixed asap. Is there anyway we could fix it rather than have to call out a service engineer. If there is something we can try can you answer in simple language as we don't know much about washing machines.
Thanks very much
Dec 21, 2010 | Dryers
Drum loose so very noisy on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Dryer doesnt work on hoover nextra HNWL 6136
I say replace power control module
Feb 02, 2008 | Washing Machines
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
