Question about Acer Computers & Internet
Installing a computer component
How to install a computer component
    Problem Solver:
  • 12 Answers
Hi
firstly we clean up the memory of motherboard then we check out of system carbon and see the software it will be solve
thanks & regards
Posted on Jul 13, 2010
I just took apart my computer and put everything back together again but i get no display when i turn the computer on.
A common problem when putting a computer together is assembling the hardware in an incorrect order. 1. Install your CPU and fan 2. Install your RAM 3. Install the graphics unit 4. The order of the other components does not matter. 5. Connect power to all components and boot up.
May 03, 2011 | Computers & Internet
I install a new motherboard for a dell studio 1735, the laptop start but in a minute after starting the laptop is off
New motherboards replaced on computers starts with several observations as regular anticipations. First the computer has to get adjusted to the new circuit arrangements. Assume that the new motherboard had all the component structures least required to malfunction. Once installed, the power circuits have to get adjusted depending on the type of components that have been installed on the new board. For example, the computer requires searching to ascertain the new means to achieving user expectation soon after configuration onto new board of circuits. The processes of the computers reconfigurations includes search every components parts comprise the new mother board. A start at power on performs basic input output devices inspections of the interior components of sound, video, storage, heating, clocks, cables, programs, and finally the external connected ports. Once the computer ascertains that the new system has the requisite details to perform desirable, it is usual to shut down automatically to restart to achieve the users expected installations. Also, the basic input output search may have discovered errors during the process and was incapable of power shutting immediately but provides the extensive nature to attaining an entire diagnosis until displaying momentarily before power shutting completely. Once the computer was able to search the entire new circuits to arrive at users momentary interface display is indication that every component is appropriate only least has the extensive capacity to display extensively. Computer automatic shut down has three possible explanations. First, the program system also known as operating system is incompatible on the computer. Usually the new mother board contains remnants of the operating system of the computer from which was extracted. Since the motherboard least contains a hard storage drive that has the operating system programs, installing a new motherboard on an old computer still with hard storage drive continues to have old programs requesting to communicate with a new circuit board. Usually, two separate operating systems are least compatible to each other where the motherboard would have for example windows 2000 installed on a windows 98 computer still with remnant hard disk drivers may attempt to power on by searching to ascertain every components, display momentarily the possible conditions to attain power shut down due to incompatibilities. Second, usually computers have component devices that operate differently. For example, similar computer may have dissimilar capacities of graphic cards where smaller computers graphic card were extracted together with the motherboard to be installed on a larger computer may not provide enough graphics capacity to display every details. Usually, the graphic card contributes to wards color resolution appearances on the computer. Compatible changes of motherboards only shy of graphics would display picture quality least achieving user visual effects. Usually advisable to change from new versions to older versions to attain update effects rather than change from older versions to new versions computer that would hardly display at power on. Third, the components that are changeable on the computers motherboard to least cause dilemmas includes entities like storage drives that may require reinstalling the operating systems as new ones are empty in content. Also, video cards, graphic cards, sound cards, expansion devices are those that add to feature improvements on the computer to attain experience. Once changing improvement devices within the motherboard, it is advisable to acquire the recent compatible to the entire computers brand model features to attain an improved experience also known as system updates or upgrades. At which point the computer should have provided in the momentary display a diagnosis observation from where adjustments to become functional is achievable. First attempting to maintain the entire motherboard changes by fixing the issues that are causing malfunctions is achievable. A hard disk drive may require erasure to capture a new system that is compatible with the entire computers components. Usually, hard storage drives are capable of causing to become volatile to allow for new operating systems software to be installed taking effect. In the situation of being unable to erase a preexisting disk, acquiring a new disk is plausible. New disk storage allows installing a new system of choice however require the entire software program. Once acquiring new disk with new software programs the computer mother board takes new effects altogether. Ascertain the functionalities of the prior existing components of the computer are necessary to acquire new disk storage and installation program software. Usually acquire a disks with vast entities to spaces to capture several new programs of operating systems, new user productivity software's and extra spaces for improvemts conditions as the computer exists. While at retail, ascertain to acquire each component parts with intent to building a whole device. The means of last resort is ascertaining the entire resources required to restore the old computer in costs to component parts, retails resources gathering if any available, inconvenience to make possible building another computer, costs of installations, technical guarantees to restore another device least recognizes as the manufacturers default. The ultimate means is discarding the old device as depleted of productivity to acquire new computer altogether. Computer resource components usually are generational where attempting to a build an old device with new parts makes the whole process redundant. The computer manufacture is most achievable entity to resort.
Feb 07, 2011 | Dell STUDIO 1735 Motherboard - H274K
How can i make my HP printer wireless?
Make sure your Computer have wirelesscapabilities in order to connect to the HP wireless printer. This is how to doit. 1. Insert the CD that comes withthe wireless HP printer into any computer that will use the printer. This willallow to setup the initial software and allow you to configure the initialnetwork settings. 2. Choose where to install thesoftware and which components of the software to install. Typical componentsfor HP printers include the network utility and project creation software. Ifyou already have software for project creation, you don't need to install this.You won't need to install either component for other computers in order to usethe printer. 3. Turn on the HP printer whenprompted. Don't connect it to a computer unless directed by the software. Ifthe printer isn't recognized by the software, you may be asked to temporarilyconnect it via a provided USB cable. 4. Choose a printer name and an IPaddress. The IP address can be dynamic or you can create a static IP address.For larger networks, dedicate a static IP address or allow the HP software tochoose a static IP for you to prevent conflicts on your network. 5. Press "Continue" tocomplete the wireless HP printer installation. The entire process can take upto 30 minutes if you install all software components. 6. Install the printer on othercomputers by going to "Start -- Printers and Faxes -- Add a Printer."Choose "A Network Printer" to view a list of network printers. Choosethe printer name from Step 4 to install and access the wireless printer.
Jan 10, 2011 | Office Equipment & Supplies
PLS NEED INSTALL
Important Notes
Computer softwares are the programs that would be integrated ino the computer by a process called installation. Available installation softwares include productivity, multimedia, creativitiy and gaming programs. Computers already have programs installed to perform also known as operating systems softwares. When a computer is turned on, the display systems making possible user experince is the defaul programs. Every additional features is capable of being intergreted in processes discribed. A required program whether in video editing is chosen after observing the already existing programs on the computer. The decsion to integrate an additional software is with consideration of an entire computer compartibilily check.
Computer situations requiring installation
1. The computer default programs are malfunct
a. outdated computer programs request integration improved features to function
b. a damage to the computer default programs requires repairs by installing.
2. The option to integrate a program to a computer device
a. several programs are capable of being integrated
Procedures of -installing softwares
component check requirements check
1. computer compartibility to software programs selections required to be installed
a. A computer capacity to hold additional softwares
b. a computer functionalities, productivity, video multimedia creation, computer gaming
c. the programs functions could determine if additonal component parts have to be acquired to complete the integration experiece
contact technical support
Dec 20, 2010 | Computers & Internet
Problem installing drivers
This issue occurs if install a Retail version of a Windows Operating System in the Computer.
To resolve the issue:
Option 1:
First install the "Sony Shared Library" in the Computer. It will be listed in the Download Page under System Components.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN110G
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers, Updates and Applications compatible with the new Operating System installed in the Computer.
After installing the Sony Shared Library, try installing all the drivers.
IMP: Restart the Computer after installing the Sony shared Library.
Option 2:
If the issue persists then try installing Sony shared Library first and then all the other drivers in the Computer in the SAFE MODE.
NOTE: While an Operating System is in the Safe Mode, it will have reduced functionality, but it is easier to isolate problems because many non-core components are disabled.
Restart the Computer and press the F8 key when the Sony logo appears to start the Computer in the Safe Mode.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 15, 2009 | Sony VAIO VGN-N110G/W Notebook
I keep getting tossed into Protection error or Blue Screen!
The harddrive from another computer, with an O/S installed on it already, is the problem.
Am I to assume the harddrive you're trying to install, has Windows for an O/S?
Microsoft's Users License states, "One GENUINE copy of Windows per One computer"
The genuine copy of Windows on the harddrive you're trying to install, has already been Activated on the computer it came out of.
(Microsoft has a Master disk of each Windows O/S. The copy the user obtains, is a copy made from this disk. It is then a Genuine copy from Microsoft. If it isn't a Genuine copy, it is an illegal copy)
When Windows is installed on a computer, it assigns 'codecs' to major hardware components of the computer.
Think of these 'codecs' as serial numbers, for the hardware components.
(No computer owner personal information is recorded. Just THAT genuine copy of Windows, to THOSE hardware components)
Some of the major components are, Processor, Harddrive, Motherboard, (More specifically the BIOS program and version, that's on the BIOS chip),
and Graphics chip. (GPU)
Change two or more hardware components, and a 'red flag' is put up. 'Codecs' do not match for the AOpen motherboard, and the hardware components on it.
(Different BIOS program, different Processor, and different GPU)
Therefore, it is believed to be installed on more than one computer.
Easiest solution would be to buy a full installation disk of Windows, and install it.
[Also go into BIOS Setup, and in Boot Order, set the first boot device to CDROM]
Sep 15, 2009 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
DRM components wont install
Open the following link and click on up[grade button:
http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp?force=1
Or download the following file and execute on the computer:
http://www.napster.com/client/drmreset/DRM_reset.exe
Jul 23, 2009 | Dell Computers & Internet
Samsung v25 shutdown
hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site: http://www.microsoft.com/whdc/hcl/default.mspx
Mar 22, 2008 | Samsung V25 XVC 2800 Notebook
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Microsoft equation
Microsoft Equation is an optional component and is not automatically installed. To install Microsoft Equation, you have to run the Office Installer, and select Custom Installation. The installation wizard will present you with the optional components to install. Find Microsoft Equation, and make sure the Run this in my computer option is selected. Then continue with the installation. Office will configure itself to include the Microsoft Equation program.
Sep 21, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
