Question about Humax DRT800 DVD Recorder
HUMAX. HDC1-2000 HDTV-RECEIVER.
RECEIVER SCANS ALL 987 CHANNELS BUT WILL NOT STORE THEM INTO THE RECEIVER,RECEIVER GOES INTO FREEZE AND THE ONLY WAY I AM ABLE TO TURN THE RECEIVER OF IS FROM THE MAINS.WHY IS THIS?
2 Suggested Answers
  • 212 Answers
SOURCE: My Humax Duovisio PVR-9200T often freezes
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
Posted on May 04, 2010
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
What does code 576p indicate?
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Oct 20, 2015 | Humax PVR9300T HD DVR
The bbc red button service on humax listing not working
You should scan for channels again, as some were changed recently.
Sep 14, 2014 | Humax FOXAT HDR DTV Receiver
Retuned my humax box and my west channels are now wales how can i change them back
You will need to manually tune to your preferred transmitter. The Humax will tune to the first decent signals it finds, so if signals from the Welsh transmitter are good and found before the transmitter you want, it will use them.
Or, you may be able to unlpug the aerial, start the auto retune, then replace the aerial after about 25% of the scan completes. You may need to adjust the % before replacing the aerial to ensure that only (and all) wanted channels are received.
Sep 03, 2014 | Humax Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Press Menu
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
Humax 8000T not used for a while, now says ''no or bad signal'' and says no channels available when it searches.I tried resetting to default settings but still no joy. When I checked signal status it says...
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
Oct 24, 2009 | Humax Televison & Video
ACIDENTLY DELATED ALL CHANNEL FROM MY HUMAX, NOW I CAN NOT GET CHANNEL BACK I HAVE ENTERED CORRECT FRQ/SYMBL ETC DETAILS.
1 - The correct sequence for  all channel data input: a.satellite name; b.frequency; c.polarisation; d.data/symbol rate; e.fec. Did you respected that for every single one?
2 - If yes then is the signal strength for each frequency above 80% ?
3 - Did you scanned all satellites after you have loaded the data?
Oct 04, 2009 | Humax Televison & Video
I have a Humax 9200T 160GB. It freezes after being powered up for 1-2 minutes. I removed the Antenna cable and SCART to TV and it powered successfully for hours. Connecting it back together it freezes...
Removed the aerial cable which enable the unit to operate.
In installation menu selected "Default settings". Once this had completed, I powered down the unit, I added the aerial cable and powered on the unit. Unit then searches for channels and stores them "save" tab. Issue resoved.
Sep 05, 2009 | Humax Televison & Video
Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Oct 25, 2008 | Televison & Video
Humax DRT800 DVD Recorder Logo
103 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
