Question about Linksys Wireless-G WRT54G Router
How to set up wep security on a linksys router that was already set up with no password it is a linksys wrt54g on lrouter a dsl network
  • 550 Answers
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Jul 15, 2010
    Problem Solver:
  • 12 Answers
Hi
Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
thanks & rgds
Posted on Jul 13, 2010
What is the wep key for a linksys wrt54g
If this is the first time you are trying to use the wireless network of your linksys and you haven't change the settings of your wireless network, then you will be able to find the default WEP key at the back of the linksys router, just flip it and you will see a sticker there. Make sure to get the correct format because it is case sensitive. If you had set it up before then you need to connect the router directly to your pc using an ethernet cable and open browser. Type 192.168.1.1 and use admin for username and password. Click the wireless tab on the upper part of the screen and select wireless security. From there, you will be able to see the set WEP key. You can edit it from there as well.
Aug 10, 2011 | Linksys Wireless-G WRT54G Router
I bought an Amazon "Kindle" Wi-Fi reading device
I do not recommend that you use WEP for security as this is no longer a secure method for wireless network.
Setting up a wireless network can be a bit tricky at times, but if you follow this step by step guide for Linksys routers, you will have your wireless network up and secure in no time.
It will walk you through resetting the wireless router and quickly setting up a securing your network.
Click here:
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Feb 18, 2011 | Linksys Wireless-G WRT54G Router
Kindle 3rd Generation -- Linksys WRT54G router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or...
I don't have a solution -- I'm having the exact same problem and I'm looking for a solution. Called Kindle tech support, and all they could recommend was to go to McDonald's to see if I can connect using their wireless. They DID say this Linksys WRT54G router is a compatible router with the 3rd Gen Kindle.
Jan 12, 2011 | Linksys Wireless-G WRT54G Router
Kindle 3rd Generation -- Linksys WRT54G2 router. Kindle won't recognize password set in router -- Always says "Unable to connect to Wi-Fi Network. Would you like to enter the passworsd again or manually...
First Check if u are Entering correct Password
Plz also Check security TYPE u have Chosen for Wireless
Might not work with Advanced Security
Try WEP or WEP
All the Best.........
Oct 07, 2010 | Linksys Wireless-G WRT54G Router
How do I create a password for my linksys router?
Have a computer connected to the Linksys router (network)
Open a browser such as Internet Explorer or Firefox and in the
address bar type:
http://192.168.1.1 [enter]
This will bring you to the Linksys router's login screen. The default
username is either "admin or left blank and the default password is "admin" or "password" without the
quotes. Enter that information. You are now in the router's
configuration utility.
Click on the Administration link at the top of the page. Enter your new
password. WRITE IT DOWN SOMEWHERE YOU WILL NOT LOSE IT. Re-enter the
password to confirm it and click the Save Settings button at the bottom
of the page. The router will restart and present you with the login box
again. Leave the username blank and put in your new password to get back
into the configuration utility.
This will set the new password to your router.
If you need to set a password for your network then....
Click on Wireless Security.
Under Security Mode, click on the Down Arrow and then select WPA-Personal, unless you have an older wireless network card in your laptop which can't use WPA, in which case, click on this for instructions on setting the Security Mode to WEP.
12) Under Encryption:or WPA Algorithms:, set this to TKIP.
13) Under WPA Shared Key, type in your desired password, which should be at least 8 characters long, but not contain any spaces or weird characters, such as $ % ^ & * #.
14) Click on the Save Settings button to save the settings.
15) Click on the Continue button.
16) Try accessing your favorite web site using the Internet Explorer, Safari, or the Firefox program, or check your e-mail with your e-mail program, such as the Outlook Express, Windows Mail or Apple Mail program.
Note: You may have to reset the Linksys WRT54G Wireless Router by unplugging the small, round black connector that plugs into the back of the router, then plugging it back in if you cannot access the Internet or your e-mail. If this doesn't work, try unplugging both the Cable or DSL Modem's power cord and the Linksys WRT54G, then plug the Cable/DSL Modem back in first, then wait about a minute, then plug the Linksys back in.
Good luck :)
Jun 13, 2010 | Linksys Wireless-G Broadband Router
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 05, 2010 | Linksys Wireless-G WRT54G Router
Need to place password on wireless router. help! Router already in use for a while. just learned that i need a password.
goto router ip
192.168.1.1
admin login
admin :blank
password:admin
wireless setup
wireless security
enable wep wpa
wep 10 digit
wap 8 alpha numeric
Apr 29, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
How do i set up a secure network
Hi! you can setup a secure wireless network by accessing the linksys setup page and go to wireless setting, it will ask u what kind of security settings, like, wep, wpa, wpa, use the wpa2 and tkip then set the password, change also the router username and password so that no one can access ur wireless router setup page, only u..
Aug 08, 2009 | Linksys Wireless-G WRT54G Router
Method to add another laptop to wireless Linksys in home. Model no: WRT546 Serial no. CDFF1G506178 password lost...tried ADMIN
just try reset in your linksys and reinstall once again the driver for it in both your laptop and set a password for it .....
Aug 07, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
119 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
