Question about Philips Televison & Video
Philips lcd tv 26 inch. 3 years old . when you switch on it is fine. afetr 2 hours part of the screen ( same vertical corner) starts breaking up and then vertical bars. on switching off for sometime and then restarting it is fine again but for shorter duration.
  • 11,361 Answers
It can be bad T-CON board, worst case the LCD panel. You can try cooling the T-CON board with electronic freeze spray for electronic trouble shooting to see if the problem goes away. T-CON is mounted under the metal sheield which you will have to remove to get access to it.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 13, 2010
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Flickering in half screen after 1 to 2 hours
Probably caused by a power supply nearing its death.
Try to verify this by placing a portable fan to the side of the set with airflow directed at the vented sides.
If this lengthens the operating time, there is a good chance that some minor components in the main supply have developed low values of capacitance and higher losses which worsen with warmth.
Listen closely at the vents with the sound turned down to attempt to detect a squealing sound while the TV is in its failure mode; if you find this, it is also a sign of power supply trying to die.
A tech equipped with a capacitance meter that measures losses at the same time, could find and replace the weakened parts without a whole lot of labor and little cost for parts.
Nov 26, 2009 | Philips Televison & Video
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Feb 03, 2008 | Mitsubishi CS-27205 TV
Televison & Video Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
