Question about Acer Aspire One Netbook 8.9" Notebook
Acer aspire one zg5, cant restore to factory settings
Ok guys, my laptop screwed up the other day so i did the alt+f10 to restore it all was well till it gets to 96% at which point it says ' restore failed reason:0xf0000006 '
so afterwards i tried to just turn it on and all i get is NTLDR is missing
so after this i figured id make a bootable usb and re install windows but just as the re-install starts i get a beautiful blue screen of death and then the laptop re starts, im now sort of stuck for ideas, anyone have a clue?
Restore laptop acer aspire zg5 to new
press and hold alt+f10 as you turn it on
Mar 10, 2014 | Computers & Internet
Aspire zg5
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Jan 21, 2013 | Acer Aspire 5720-6661 Notebook PC
How can i make factory setting for Aspire 5610 without recovery disc and/or with recovery disc
You do not have to make factory setting, infact you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10 (try both), it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Acer Aspire 5610 Notebook
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Jul 16, 2010 | Acer Aspire One PC Notebook
Can any one help with how to restore factory setting on an acer aspire 5050,
All Acer laptops at the moment use a combo key use.
Boot laptop and at the Acer BIOS screen press Alt+F10 (keep tappin F10 while keepin finger on Alt).
Feb 19, 2010 | Acer Aspire 5050-3242 Notebook
Need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Jul 31, 2008 | Acer Aspire 3000 Notebook
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
1,817 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
