Question about Canon Office Equipment & Supplies
How to do photocopy both side of the paper without open tray in canon ir2018n?
    Problem Solver:
  • 12 Answers
First we go to menu of photocoier and give command in setting section and celect the both side of paper
Posted on Jul 13, 2010
How change paper size iR2018n?
hi am from Ethiopia,on this machion i mean canon IR 2018 first of all on paper tray with indicating arrows secondly display setting(tray setting on device display
Dec 22, 2017 | Office Equipment & Supplies
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Sep 05, 2016 | Canon IR1018J Black and White Copier
Canon ir2018n paper with line
If you only have a line when using the adf, cleaning the small slip glass to the left of the copy board glass
Sep 03, 2012 | Canon iR2018N
Canon Pixma i4300. Front output paper tray pounced on by pet cat. Closed it up and opened it again When I try to print I get this message: "Document printing cannot be executed because the paper...
If you can remove the tray - have a look at it and it should come out without much force by pressing on the sides. If it comes out you may see the sensor inside that maybe is bent up and is not registering that the tray is open. If you see it you can bend it back down. You can also shoot canned air(with the tray in the out position of removed from the machine) and a piece of debris may come out. Use short squirts or the can gets very cold. All the office supply places and computer stores sell the cans of compressed air.
If none of the above helps, you can always communicate directly with Cannon at:
http://usa.canon.com/cusa/office?pageKeyCode=contactUsLanding
I have found them to be very helpful. Good luck..............................Pete
Jul 20, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have a printer canon inkjet mp140 and i don't know how to insert the paper from the tray that is down or from the upside tray
Well, you should insert the paper "from the upside tray". Follow these steps:
Align the edges of the paper before loading it;
Open the paper support of "the upside tray" and pull out the paper support extension;
Open the paper output tray ("tray that is down");
Adjust the position of the paper thickness lever;
Load the paper in the auto sheet feeder with the print side facing UP;
Align the paper stack against the right side of the auto sheet feeder.
Pinch the paper guide and slide it against the left side of the paper stack.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Paper jam and possible failure to pull A4 paper ?
1- you must remove the jam paper first
2- set the tray to LETTER or LEGAL not A4
A4 is european size not used in the U.S
Make sure the paper adjuster in the tray is touching the end of the paper size, also there should be some markings in the tray.
The noise is coming from the jammed paper, it is trying to feed itself but is stuck.
Dec 24, 2007 | Office Equipment & Supplies
74 people viewed this question
old marine
old marine
