Question about Honda Horizontal OHV Engine for Non Pumps 160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2
Cant get engine to idle i have it in my go kart runs ok when accelerating
  • 45 Answers
Sounds like low idle screw could be turned up a bit
Posted on Sep 09, 2010
2001 eclipse engine dies when accelerator is not engaged. Engine will not idle. runs ok if accelerator is pressed. V-6 3.0L
Clean the throttle body(inside as best you can) clean the idle air control motor, and change the air filter if dirty..
Dec 16, 2014 | 2001 Mitsubishi Eclipse
Have a go kart , it runs but shuts off after I let off the accelerator , any ideas
Sounds like the carb needs adjusted. Could just be the idle is too low but more than likely it needs cleaned and adjusted google the motor type and carburetor adjustments
Dec 01, 2014 | Video Game Consoles & Games
Rough idle/ not accelerating/coolant leak
Rough Running Engine - James on Engines #2 - Bell Performance
https://www.bellperformance.com/blog/rough-running-engine
Apr 21, 2015 - When diagnosing an engine with a rough idle, there are certain things that must be ... If the problem does not reoccur, the codes will be erased by the computer. ... when accelerating the vehicle, which causes a higher fuel demand. .... it was water in gas...added added Gas LineAntifreeze/Water Remover.
Mar 17, 2017 | 2000 Ford Focus
Motor skipps during acceleration on 1998 s10 pick up 4.3 v6
a bad plug wire will break down when accelerating but act ok when idling change plugs and wires
Dec 27, 2012 | 1998 Chevrolet S-10 Pickup
Duromax next generation xp10000E idle surging problems
I have a duromax 16hp engine on a murry go kart ran perfectly fine we took engine off kart painted kart put motor back on go kart now wont idle unless holding choke halfway open and new gas we drained gas before we started work on kart plesas help only about 10 hrs
Dec 26, 2012 | DuroMax XP10000E 4-Cycle Gas Powered...
Engine idles but does not accelerate when pressing on the gas pedal?
what car is it? your car using carb or fuel injection
Jul 27, 2012 | 1995 Nissan Altima
Engine runs not smoth when steping on accelerator
OK. Most automotive shops will test CHECK ENG LITE for abolutely free. Once you have the code, this may be the cause of your woes. Start there and you will not be guessing.
Sep 10, 2009 | 2001 Toyota Echo
Engine revs take off on there own
Check out the throttle sensor.If its ok then you have a injection pump problem.IF you cannot turrn the engine of when the car starts reving then its running on its own oil.
Jun 08, 2009 | Renault Sport Cars & Trucks
Honda Horizontal OHV Engine for Non Pumps  160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2 Logo
106 people viewed this question
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
 Brian Main
Brian Main
Gil Shultz
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
