Question about Kitchen Ranges
My ge cafe over the range microwave occassionally does not work. The problem seems to center around the touchpad which becomes unresponsive for hours at a time - all other times the microwave and touchpad works fine. It seems to happen after the range underneath has been used.
  • Kitchen Ranges Master
  • 17,130 Answers
Failure of the touch pad unfortunately is a very common issue with the microwave ovens. there is not much that could be done except to change the pad. As a last resor tyou can open and look for the connection of the pad to the main board to be bad. clean the board especially if there is any signs of insects/ cockroaches within. clean and check. What you can also try is to slowly open the pad and make up the tracks with a carbon pen which could be bought from an electronic shop. This must be used in the suspected buttons which fails to respond. Hope this will help. Good day
Posted on Jul 13, 2010
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
My question is with regards to the control panel of a microwave.
GE Cafe Microwave Touchpad Failure and ... - YouTube
? 7:28
www.youtube.com/watch?v=ZBI2EDuw7iM
Dec 30, 2012 - Uploaded by Andrew Bradford GE Cafe Microwave Touchpad Failure and Possible Solution. ...Quick repair GE microwave touch control key panel doesn't w - Duration: 3:43.
Sep 29, 2015 | GE Wirlpool Over The RanMicrowave Oven...
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
Oct 06, 2014 | GE Profile Spacemaker Over-the-Range...
HOW DO I CHANGE OUT THE TOUCHPAD FOR JNM1731DPBB
I'd suggest you contact Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio. He just repaired my GE keypad on a Model JVM2070CH02 microwave (GE doesn't make just the membrane keypad available--you have to purchase the entire control panel ($548.00 through a local parts distributor). Matt's turnaround from the time I removed the keypad to the time I re-installed it was only 8 days--and it only cost me $100, which included the return shipping. I'm sold on Matt!
Jun 29, 2013 | General Electric GE JNM1731DPBB 1.7 cu ft...
Oven shuts off while baking. No error code, it just shuts off and none of the buttons work on the GE Cafe range.
I have the same problem. GE repair man replaced the electronic control panel. If anything, the problem is worse. Does anyone know what ACTUALLY makes this range shut off as it gets up to temperature while baking? I don't really want to pay the repair man to fumble around debugging this.
Aug 24, 2010 | GE Cafe CGS980S Kitchen Range
Touch pad not working properly
That sounds like the interface controller which is just a little computer chip that cotrols everything and watches the signals from the touchpad is having problems. Usually these will behave like this and then just stop so your touchpad is totally dead. It may take out the time displays as well.
If you have warrenty from GE or the store it will be covered. If you are not covered then it can cost about the same or more as a new microwave as they will have to replace the board. Check your warrenty's, then check the repair cost and check replacement costs. Usually a new microwave is the cheapest.
Apr 28, 2010 | GE JVM1740DM Microwave Oven
I have a LG microwave oven model LMVM2075SB. It's
We just finished replacing the touchpad on the same model microwave. Several of the numbers and other controls on the pad stopped responding to touch.
You could have the same problem. These touchpads seem very fragile to me.
The touchpad itself was only $25.00 plus shipping. The pad is attached with adhesive and pulls off when heat from a hair dryer is applied to the pad. The new one comes with new adhesive and is fairly easy to attach. The problem arises when you have to connect the wiring from the touchpad to the microwave's circuitry. There is a circuit board in the door which this wiring connects to, and the door has to be disassembled to get to this board. The door components are held together with the two screws that hold the handle on, and numerous plastic tabs.
I would guess that it took us about 2 hours to do the job. Most of the time involved removing the door, disassembling it, and reassembling it.
Everything works perfectly now.
Oct 11, 2009 | LG 30" Over the Range Microwave Hood with...
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
Inspiron 1525 Touchpad has a mind of its own
I would try using what they call a cool mat. It sits under your computer and plugs into your computer per USB. It helps keep the computer cool. They cost like 25 dollars.
Mar 26, 2009 | Dell Inspiron 1525 Notebook
Kitchen Ranges Logo
369 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
