Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
The lower shaft on my ryobi stoped turning, how do i fix this problem.
    Sniper:
  • 56 Answers
You didn't quite give me enough info on which machine you have ... but if it is one that allows the lower half of the shaft to be removed for using other implements, disconnect the shaft and try to turn the inner splined shaft by hand and see if the head turns, if not you may have a broken shaft cable or a frozen bearing in the shaft head...this will necessitate removal of the head and replacement of either the shaft cable or the machine head...if all is working then check the shaft going to the clutch...hope this helps... ;-D
Posted on Jul 17, 2010
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
My Ryobi bc30 trimmer engine runs, but the shaft does not turn. The problem is not with the "lower" shaft with the head but the shaft connected directly to the engine.
That shaft has a hexagonical male fitting that slides into a corresponding female fitting on engine. If either is worn or stripped, the shaft will not turn. Either the male or female have to replaced to restore operation.
Oct 26, 2013 | Garden
I have ryobi rlt 30 strimmer and the shaft seems to be turning but the head has not got enough power in the shaft to turn the head and it all so seems to be vibrating where the shaft can be joined together...
For starters, check the condition of the LOWER flex- shaft.Remove the LOWER from the upper shaft, and while turning the string head, see if the top end of the flex shaft turns also. I think your unit has a clutch which makes diagnosing the flex shaft in the UPPER shaft housing (the one attatched to motor) a lot more difficult. If the upper flex-shaft is clutched, it WILL NOT turn when turning over the engine (unless the clutch is bad or has malfunctioned; which is rare). To inspect the UPPER flex-shaft, you will have to do a dissassembly (partial) at the motor housing cover in the front to pull the upper shaft out to inspect it. To get it all the way out to look at it, you will have to remove the throttle cable from the arm on the carb and disconnect the STOP switch wires going to the coil (located UNDER the front motor housing cover). Post back with what you find. Wish I was there to help.
Jul 14, 2011 | Ryobi Garden
RYOBI Model ELT1100QFA. The lower shaft gets hot during use. I believe the lubricated packing is missing on the curved portion. Where might we find a packing material in Sydney, AU?
I have pulled a couple of these apart; they use a blue plastic lubricating blocks to keep the flexible shaft away from the shaft wall.
I found with two different shafts that they disintegrate with a few hours usage. Tried grease but the shaft drive still failed. I tried talking to Ryobi who tell me that there is no separate parts in the assembly (and parts drawing confirms a single part number for the entire shaft assembly. Took them months before they eventually gave me one off the shop floor.
The 1100QFA would be a very good multi-function if they fitted bearings or some other solution.
Oct 22, 2010 | Ryobi Garden
Ryobi 825r trimmer turns very slowly
The connection between the two shaft has a molded lead piece that the upper half is suppose to match with the attachment. If it not square you will need to replace the lower shaft.
Merry Christmas
Dec 22, 2009 | Ryobi Garden
I have a 790r and the detent pin on the lower
That pin should be the same as other Ryobi trimmers. Find one for one of them and compare. Lee
Sep 15, 2009 | Garden
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
350 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
