COPIER>FUNCTION>CLEARERR Clears error codes.
(Cleared error codes: E000, E001, E002, E003)
Operation method
1) Select this item, and press the OK key.
2) Turn the main power OFF/ON
There is a problem in developing assembly.
Check the toner leakage from the toner buffer block within the developing assembly. Replacing the patch image reading sensor should do the trick.
first remove all paper trays and inspect for paper behind the tray area and inside the machine second verify if the paper trays are set to the correct paper sizes this is easy just look at the screen under paper trays and all trays should tell you what they are set to
Hello, the drum units isn't on the "rotary drum". To change them you need to pull out the drum holder out, which is behind the toner hoppers and beneath the transfer belt.. Its difficult to explain by the words, for installation manual send me the mail on [email protected].
