Question about Toshiba Computers & Internet
This system can not use toshiba accessibility (((this msg appeare when I open accwssibility)))0
  • Anita Kraack
    Anita Kraack Mar 04, 2015
    Hi lovef_3, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Virus in Toshiba L450 laptop will not allow me to access
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Feb 24, 2012 | Toshiba Satellite Pro L450 Notebook
Tip
LG DV582H region free code
Here are the steps to make your LG DV582H DVD region free.
1) Power on (with no disc)
2) Wait for msg "No disc"
3) Open tray
4) Push three times number 0 (i.e.: 0 0 0)
5) A blue screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
7) Press Pause (A msg say that you have to press de new code and them press pause to confirm....so, is to easy)
8) Close tray
9) Turn off
Works 100% for my LG DV582H region 4, now its region free!!
Good Luck
on Jan 03, 2011 | Audio Players & Recorders
Toshiba Satellite L450 Series - no access - black screen - was diagnosed with virus - using recovery disc - appears stuck on
your notebook.
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
I need the unlocked code for my LG DV556
3) Open trail
5) A screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
8) Close trail
9) Turn off
Dec 29, 2010 | Televison & Video
How can I unlock the region code on my LG DV 556 ?
3) Open trail
4) Push three times number 0 in remote control (i.e.: 0 0 0)
6) Press 0 (zero)
7) Press Pause to confirm
8) Close trail
9) Turn off
Dec 12, 2010 | LG Televison & Video
Need a multiregion unlock code for LG DV582H?
3) Open trail
6) Press 0 (zero)
8) Close trail
9) Turn off
Good Luck
Nov 29, 2010 | LGDVB418 DVD Player
How doI reset my Toshiba Laptop with Vista 64 bit to factory settings?
There are two ways to reset your Toshiba Laptop to factory settings.
First is using Recovery Media Disc and the second is the hidden partition on your hard drive.
If you're going to use Recovery Media Disc follow these steps:
If you have two or more recovery media disc try to insert first the disc that has a label of 1 of 2 or 1 of 3. Then turn of your laptop.
Make sure that the disc is inside. After that try to find the letter "C" key on your keyboard. Now turn on your laptop and keep tapping the letter "C" key. If you have successfully accessed the Boot Menu choose Toshiba Recovery Wizard.
After choosing the Toshiba Recovery Wizard there will be a big warning screen that will appear choose the option yes and after that you will have a series of option. Remember to choose always the first option after the big warning screen appears.
That's it. You will have a message that the Windows is initializing files.
That process will take 1-2 hours for it to finish.
Hidden Partition on the Hard Drive.
Turn on the laptop and as soon as the laptop turns on press and hold down the number 0 key (the number 0 it should be on the top of the keyboard beside the number 9 key) keep 0 pressed until Toshiba leading innovation appears. Usually you will have a beeping sound when you are trying to access the System Recovery of the Hard Drive. That's an indication that you have successfully accessed the Systrem Recovery of the laptop.
Wait for the screen that say Windows is loading files.
After that you will see a big warning screen the choose yes and
Choose 1st option always.
Cx able to initialize the partition.
Disconnect cables and turn off the wireless switch.
Recovery would take 1-2 hours for it to finish.
Nov 13, 2009 | Toshiba Satellite L305D-S5904 Laptop
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Feb 26, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
845 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
