Question about JVC GR-DVM70 Mini DV Digital Camcorder
My selector buttons for operation came off?
The wheel and plastic button are off.Are they difficult to put back?
I solved this problem Friday night and I have to give credit to a Blogger who suggested buying JB Weld to re-connect the center ring. I cannot find that blog again but if you are out there, THANK YOU VERY MUCH. Here is what I did in more detail and I hope it helps you:
1. JB Weld is and epoxy sold at Home Depot. Go buy it for $5.00
2. Get a piece of tin foil and place the equivalent of 1 drop from each tube onto the foil. The product is activated by mixing the 2 drops together. I mixed this this with a wooden toothpick.
3. Put the outer ring in place on the camera and be sure to line it up correctly. Practice this several times if you have any doubts. Also practice dropping the center ring into place wtih the appropriate alignment before you apply the epoxy! If you do not have a steady hand find someone who does and let them do this for you.
4. After you mix the 2 drops together with the toothpick, apply just enough to the 4 anchoring post on the center piece to cover the tip of the post. This is a very small amount and had be questioning whether it would be enough. It was perfect. I did not apply any to the center post. Not sure if this was something that would be okay.
5. With the epoxy on the tips of the post, carefully drop the center ring in place (play/pause button should be straight up). Make sure that it is in place and put a heavy book on it for 24 hours. I used a Websters Dictionary.
6. Remove the book and it should work for you.
I feel confident that I saved myself a $400 fix.
Posted on Oct 26, 2008
How do I make a button hole
Put on your buttonhole foot. Slide the foot plate back and set the button in the back...this is how the machine knows how big a buttonhole to make. Pull down the buttonhole lever, gray plastic, which is to the left of the needle. Now use the stitch selector to select the buttonhole. Test your machine on a piece of scrap fabric to make sure your buttonhole function works, before trying to sew on your garment. If it does not work, then bring your machine in to your local Baby Lock dealer.
Dec 27, 2011 | Baby Lock BL1556
Warning light on dash board, skid back wheels
his means your traction control is switched off. Somewhere on the dash or near the gear selector is a button with a similar symbol that has probably been pressed by accident. Press the button to turn traction control back on
Jul 19, 2011 | Lexus IS 250 C Cars & Trucks
My 1999 chevy z71 is stuck in 4Low and now none of the buttons light up? I can not get it back into 2 wheel drive or even 4high
the first thing is to check all your fuses, if fuses are good then you may have a bad switch or a bad selector motor,
Apr 21, 2010 | 1999 Chevrolet Silverado 1500
Logitech G25 racing wheel controls dead / No sound
A consealed plug under the wheel console had pulled out
The sound lead had been disconnected to allow another device to be fitted
Jan 18, 2010 | Logitech G25 Wheel And Pedals Set
Selector switch stuck in 4lo
pull 4wd fuse inside fuse panel and atc fuse from underhood fuse center, truck wil go back to 2wd,check control box behind pass.side kick panel ,elect. connector at box,full of corrosion will cause weird 4x4 problems!
Mar 27, 2009 | Chevrolet Blazer Cars & Trucks
Program selector knob keeps turning
Difficult to pinpoint problem from symptons.
Try this link, there is a lot of information here which may help you.
www.washerhelp.co.uk/diy-repair-help
Nov 24, 2008 | Indesit W 123 Front Load Washer
Back wheels will not click back in. have tried to clean the inside incase of a build up but none
I had the same problem. It was a sort of buildup which was ammazingly problematic. I undid the small screws on the inside of the wheels (1 screw per wheel). Be careful because a spring and black plastic piece will fly out. then use a screw driver to push the gray wheel removal button. You will find that it seems sort of stuck. Clean inside the plastic chamber and the slider piece...I just used my fingers. Then you will see that it slides freely. Put the sliding piece in the correct position for when the wheel is removed...button depressed. Put the wheel on. Push the sliding piece with a screw driver so that the wheel is locked and the button is popped out. Put the spring back in and the black plastic piece back....hold it on and redo the screw. The wheel should be locked on. I am not sure if you would be able to remove it and put it on again...I think so, but I am not trying since I don't usually remove the wheels anyway. I hope this works for you too! Good luck!
Oct 25, 2008 | Quinny ZAPP Stroller
1990 Suzuki Escudo 4 wheel drive
As far as I know the procedure should go something like this...
Stop the vehicle, engage the parking brake and if applicable, get out and turn the hubs on the front wheels from Free, to Lock.(You may not have these on a Suzuki, they may be auto-lockers)
Get back in the vehicle and put the transmission shift selector into Neutral.
If you have a manual transfer case, move the selector-shaft to 4x4-High, or 4x4-Low -- whichever is desired. Now, putting the vehicle in gear with the transfer case is sometimes somewhat difficult. As long as the vehicle's transmission is in neutral, don't worry, the gears inside the transfer case are big and beefy -- Don't be afraid to be rough -- Again as long as the transmission is in neutral. You may also have to disengage the parking brake and slightly let the vehicle roll forward or back with your foot-brake to get the Transfer case to lock into place.
Once 4x4 of the selected High, Or Low range is selected, usually indicated by the vehicle jerking slightly with a slightly loud clank/thud. Move the Transmission selector out of neutral into your desired gear (Drive if Automatic, if Manual, whichever gear you pull out from). and voila! You should now be in 4-Wheel-Drive.
To disengage 4-Wheel-Drive. Just reverse the steps.
May 16, 2008 | 1990 Suzuki Sidekick
JVC GR-DVM70 Mini DV Digital Camcorder Logo
139 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
