Question about Bush 5693D 24" TV
Tv stuck in configuration setting wont recieve channels
I purchased a bush 26 inch flat screen over 2 years ago in the uk. i have now moved to ireland and my tv no longer recieves channels. as soon as it switched in it is in the configuration options ir channel searching options. antenna plugged in and it wont pick up any channels..this never happened in the uk . the tv is in good condition and switches on no problem but just goes straight to this page...
please can you help...
5 Suggested Answers
SOURCE: This BUSH ws6671sil Wont switch on
It requires remote
Posted on Jun 15, 2008
vortash
  • 431 Answers
SOURCE: Cannot tune analog channels on Bush 32'' LCD TV
Hi I am Vortash not a set I have worked on but suggest that the solution will be in the user manual , if you have no user manual try this site http://www.safemanuals.com some of the downloads by adobe pdf file are free others reasonably priced I hope this is of help Regards Vortash
Posted on May 15, 2009
  • 1632 Answers
SOURCE: tv settings on my 26 inch hd readt tv settings are
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
SOURCE: Bush 29" Flat Screen TV IN INDIA CITY OF CHENNAI NEEDS REPAIR.
Please contact below address for Madras branch as they are authorised Bush service centre
Location : U/12 A, Yogi Complex, New Rander Road, Surat - 395009 Phone : (0261) 3066848, 6548278 Regards//Ravin//London
Posted on Sep 18, 2010
The how to clear Configuration screen on Bush LTD TV, cannot get channels
Sounds like main system control memory IC fault. Contact any service technician to replace it.
Jul 14, 2016 | Bush Televison & Video
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
I have moved to Poland from the uk and brought my bush 26 inch tv with me and now it can only catch the audio of channels and not the video. Can anyone help?
Hello, you will need to change the frequency chip which modulates the picture. Each country has its own video scan rate. Most of the countries use the same audio chip but not the picture/video scan chip. A technician should do it for you for a reasonable price. I hope I have helped.
Mar 24, 2011 | Televison & Video
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
Hi, I am trying to tune in my bush tv without success - I bought it in Ireland but the tuning does not give ireland as an option.... what can i do?
When selecting a country, chose Australia not the UK as Australia broadcast in VHF, whereas the UK do not. Then hit the search button and it should pick up the 4 Irish channels, no problem.
Oct 18, 2010 | Bush DVD142RC 14 in. TV/DVD Combo
I bought a Westinghouse 26" Widescreen LCD tv less than a year ago and we are having troubles with the HDMI 1 channel. My son has his XBox 360 hooked up through this channel and it will randomly go blank...
I would recommend to call the Westinghouse customer service since you are at least close to the year warranty, their number is 1800-701-0680, other than that the only thing you can do is to do a factory reset by going in to the menu, go under the settings tab, and it will be the last option.
Nov 15, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Maxim 11-54 26 inch lcd tv switch mode power supply blown up need new one
I have a Maxim 15" Portable LCD TV with built in DVB-T Tuner.
It has worked well for 2 years.
Now when you switch it on set to DTV
Starts to reload the channels
Once it has found 90 channels it moves to Add and will not add any.
There are no stored channels from the built in freeview.
However we still have the normal 4 on ATV.
Any advice.
Aug 10, 2009 | Televison & Video
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Bush 5693D 24" TV Logo
55 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
