Monitor failure hello thank you for your reply i have taken out the screws but still having difficulty getting into it. as the monitor is not powering up would you know if there is an internal fuse for a simple fix or does this mean its life is over! thankyou vic
  • noseeum May 15, 2008
    I have a black screen
  • hubbgaughty Dec 06, 2008
    When i press the power button it will turn blue for 3-5 secs the turn right off. The screen will stay like as if it was turned off.
  • 180 Answers
Vic,
Try to send the photo of your monitor esp view from behind and side view of may be I could provide you more help.
As for your notice no power does not meant the the fuse only blow.There might be other component shorted. Or if you have the technical background surely it will help you much.
Thank you for reply.
jemmy
Posted on Apr 20, 2008
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
When I power on the monitor, I get a message on the screen( INPUT SIGNAL OUT OF RANGE) then I can see Power management under and the monitor goes off after 20 seconds..what can be the problem?.thanks
  1. First check the pci cable is properly connected to your CPU.
  2. Make sure it is not loosen and it is properly screwed.
  3. Check the pins if it still intact and the wire is not worn out.
If you have additional questions feel free to reply to this solution. Thank you.
Feb 11, 2013 | LG Flatron L1515S 15" LCD Monitor
When you power on the monitor a loud buzzing noise is made and then the monitor shuts down
Hello, welcome to Fixya!
This sounds more or less like one or more bulged capacitors on the power supply board inside the monitor. Usually, excess power is what affects these capacitor most of the time.
Unplug the monitor from the wall, get a screw driver, open the monitor back cover in order to gain access to the panel/board. Look for any visible bulged capacitor. If you don't find any, use a ohm meter and continuity tester to read the capacitor and other component on the panel so that the fault can be detected.
If you find any faulty capacitor or other component, use a soldering iron to remove the faulty component, take it to any electronics parts store or visit www.shopjimmy.com
Get the exact value of the defective component and solder it back. Power should be restored after doing do.
If the above task too technical for you, ask a family or friend who has the ability to assist you. (Two good heads are better that one)....
If you are still having any difficulty, please let me know and I will respond to you.
I wish you good luck.
Regards.
Nov 03, 2011 | Acer X233H 23" Monitor
LCD FAILURE
More likely the power supply/inverter board may have failed due to bad DC caps which happen after about 2~3 years.
http://www.shopjimmy.com/power-supply-unit-200-000-170dtlbmh-from-viewsonic-va1930wm-2.htm
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic and all others monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 31, 2010 | ViewSonic VA1930WM LCD Monitor
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
Replaced battery and still having electrical
Hello Sir, It sounds to me that nothing is wrong with the Alternator, but with some type of connection which runs that way. The Computer System is getting a Low Voltage signal from the Car's Alternator and thus displaying " Check Charging System ". In this case you have to focus on the connection from the Alternator. Check for any plug sockets or bolts are rusted ore loose. Somewhere there is a Power wastage going on or leak which is giving the Charging system warning. Try to check the connection to battery, see if it is loose. Check its terminals first. Make sure the Bolt and the Plug in the Alternator are tightly screwed and firmly attached respectively.
Try my above guidelines and reply me if you are having any difficulty.
Thank you Sir, Have a nice day.
Oct 20, 2009 | 1999 Ford Explorer
Monitor blinks off for about two seconds and loses power.
This problem sounds like a failure of the monitor power supply switching transistors breaking down under load conditions.This unit needs to be taken to a service center for repair. It also could be other intermittent components affecting the power supplied to the monitor. Hope this helps.
Apr 07, 2009 | Computers & Internet
HP F1930 Capacitors
This is how I learned to open my f1703hp monitor not sure if f1903 hp is the same...I got my open and going to replace power board waiting for the mail LOL.
http://www.fixya.com/support/t862133-open_f1703
Jan 20, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Power will not come on
If the power supply failed after a power failure is not a good sign because when the power came back it was higher then 120 VAC and could have damaged the microprocessor. Most of today power supplies are not well regulated and a slight increase on the 120 VAC it will also increase in the power supply, giving more power then needed.
It could have damage the power module as well.
Let me know if you need further assistance.
May 31, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
441 people viewed this question
David Payne
David Payne
