Question about Brother IntelliFAX 4100 Laser Fax
When I fax out the receiver gets a black streak down the side of the page I faxed????
  • 215 Answers
Clean the glass underneath the control panel. could have white out or something on it. however, if its a bunch of streaks, it could be your CIS, or contact image sensor, is bad. will need to be replaced by a tech.
hth,
razors
Posted on Jul 13, 2010
Faxes being sent with major streaks
Open the cover where the documents are loaded and clean the thin glass there. It may have some white out or dirt on it.
Jan 20, 2012 | HP 640 Inkjet Fax Machine
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
WE HAVE A FAX MACHINE THAT HAS A BLACK LINE GOING DOWN THE PAGE WITH FAX IN AND FAX OUT
For outgoing fax lines, check your scaner rail for any streaks, dirts or similar and clean scaner.
For incoming fax streaks, you can only check your drum unit for lines on surface and replace it, or lines is there because other side has dirt or similar on their scaner.
Hope that helps!
Aug 09, 2010 | Office Equipment & Supplies
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Streaks of black ink down the pages of faxes
Hello.
It might be as simple as changing the ink. If still a problem, the FAX may need cleaning.
Hope this helps.
Apr 02, 2010 | Brother IntelliFAX 4100 Laser Fax
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
181 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
