Question about Sport & Outdoor - Others
Hi I just got a new Mr. Meat Smoker (li'l Smoker) There were no instructions on how to put it together. Can you please help me???? thank you!
  • 883 Answers
SOURCE: char-broil water smoker
first, a charcoal fire in bottom tray, then a pan filled with hot (boiled) water above it, then the meat on top tray, then keep lid on a long time (hours) without peeking and remember to keep charcoal topped off. you should also soak hardwood hickory sticks in water for a day or 2 and wrap in aluminum foil with small holes punched through and place on top of charcoal to provide smoke. usually a large chicken is done in about 4 hours.
Posted on Oct 13, 2007
e-Guru
  • 3917 Answers
SOURCE: lost instructions for putting the b.e jumper together Help PLEASE
http://www.kidsii.com/documents/pdf/30917BabyEinstein_MusicalMotionActivityJumper.pdf
Please find the instruction manual from the link provided above.
Thanks
Have a nice day.
Posted on Mar 20, 2009
SOURCE: I received a used brinkmann smoker w/out
I don't know how much water, charcoal or wood chips to use. Or even where to put the water and charcoal. Is there a manual for this or can I get instructions.
Thanks
Posted on Apr 25, 2009
  • 200 Answers
SOURCE: instruction manual to put bicycle together.
Too long and complicated to go over everything sooo....Google bicycle assembly and your answers are at your fingertips....good luck to you friend....Tim
Posted on May 12, 2009
SOURCE: putting it together
Goshhh I have the same problem!!! and my c-section is tomorrow and the worse thing I cannot afford to buy a new one
Posted on Jul 23, 2009
How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
Hi karin 1967...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Sep 24, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
Sep 18, 2011 | Grilling
There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
Hi dan480volts...
Maybe this will help you
Sep 16, 2011 | Masterbuilt 20050106 Propane Smoker
Do you put the wood chips directly on the heating element?
Hi bobsbbq3u...
I am sending you some smoking information on how to use your smoker..
Sep 07, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I need instructions on using my big chief smoker as I haven't used it in a couple of years and lost the original instructions - basicly I am set to start smoking Salmon and need the preparation...
Hi jmcomber..
To use your Brinkman,Luhr Jensen Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
Aug 05, 2011 | Luhr Jensen Big Chief 9890
The best way to cook on this grill and how do you use the smoker on the grill. I put some meat on this grill and all my meat burn up. also I will like to know how to use the small smoke box on the side.
Hi dale37...
The small smoke box on the left is used to put your charcoal/wood in, this is where your heat and smoke will come from to cook your meat.
You will adjust your heat going to the large side by adjusting your air vent/s.
It is meant to cook the meat slowly as to make it "fall of the bone" tender.
Great for doing pulled pork also....just takes lots of time because your slow cooking the meat.
Do not use charcoal/wood under the big grill side unless you plan to stay with and turn the meat to keep from burning it.
Jul 30, 2011 | Char-Broil Silver Smoker
Have charcoal grill/small smoker. burned the meat in the small smoker. Do i put meat on the grill side and use the small smoker for charcoal and wood chips only? my grill did not come with a manual
It depends on whether your trying to smoke the meat or grill the meat. You can't do both at once.
If you want to grill the meat, don't even fool with the smoker part. Put the charcoal in the grill side, light it and allow it to get white hot, before putting the meat on to sear it on both sides first, before moving it to a cooler part of the grill to finish cooking to your likeness.
If you're trying to smoke meat or whatever, you use only the smoker side for heat and smoke. By, usually using some type of hardwood, like Oak, Mesquite , Pecan. etc. However, the meat or whatever you want to smoke, goes on the grill side (No charcoal required under it), because smoking is a low heat (200 - 225 degrees F) slow process. Any where from a couple of hours up top 8 hours, depending on what and how much you're smoking. It's often referred to, as "Low & Slow."
Hope this helped you to better understand how a combination grill-smoker works. Once you do a little receipe research and get the hang of it, you'll really enjoy it.
Jun 18, 2011 | Masterbuilt Grilling
I have purchased a used upright New Braunfels Smoker and need an instruction manual on how to use it, ie. how much charcoal, cooking times, etc.
fill it almost half way spread it evenly and make sure the coal is fully fired before you but any meat in. If charcoal still burning not fully fire and red do not put any meat in the grill. Cooking will depend on what you cooked and quantity of meat. The more the meat the longer it will take. My suggestion is to keep your eyes on what your cooking and if need to pull the meat out and test it if needs to. By testing the meat here and there paying attention with hands on will give you and idea how your grill works. everyone cook or smoke differently, some like it juicy and other like it juicy/dry or fully cooked. Buying a grill is like having a new girlfriend, you have to get the feel to know that person. Smoking will take a bit longer than standard grilling. Hope that help some..enjoy!
Jul 10, 2009 | New Braunfels Cattleman Smoker 99204805
New electric smoker no instructions!
Put some water soaked hickory chips and some liquid smoke with chicken stock or pinot grigio wine or both in the pan above the heater element. Put yer rubbed and marinated meat in top above the wood mix. Plug it in. Pop a top on a cold brew of yer choice. :D The idea here is low and slow. You want the meat to be at or around 200 and the smoke to flavor the meat. This ain't no grill in 30 and eat, it is a low and slow smoker. It takes all night or day to cook stuff correctly. Low and slow my nizzle :D Party on! What time do we eat? Saturday? You betta get started. LOL
Jun 25, 2009 | Masterbuilt 20070106 Electric Smoker
How do I use a Cadac smoker.
The cadac smoker cooker is probably the easiest to use. Lift all the inside bits out and put about 3 desert spoons of wood chip for smoking on the big plate at the bottom. Return all the other pieces except the lid. Use the low gill for chicken and bigger pieces of meat and the tall grill for flat pieces of meat and fish. It takes about an hour and a half for a chicken. Hope this helps.
Michelle.
May 02, 2009 | CADAC Grilling
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
