Question about Intel DG965RY Motherboard
After turend on there are 3 beeps, no display, ram are ok tested
When turned on there are 3 beeps, the keyboard is powered on, there is no display, the cpu fan is running, the processor is a dual core 1.6, DDR II 1gb of ram, the processor and Ram tested OK on other PC, the motherboard was 3 years old, cmos battery is ok. plz help.
    President:
  • 627 Answers
It is a memory problem. Verify if they are plugged in the mainboard slot.
Posted on Jul 13, 2010
Ms 7399
The problem could be with the mother board.It is difficult to pin point the problem without checking Power supply, RAM and motherboard. Before going to any conclusion first disconnect everything from the Motherboard. i.e front usb connectors, front audio connectors, hard disk, cd/dvd drive and floppy drive (if there is one), cmos battery, keyboard and mouse. Now start the system. If there is no difference check with another power supply. Also clean the cpu fan if it is choked with dust.
When looking for a motherboard it may be difficult to get the same type. U may buy a board which supports core 2 duo processor and DDR II RAM. Your machine may be having DDR II RAM. Also boards are available which supports core 2 duo and DDR III Ram. That's all.
Mar 30, 2014 | Computers & Internet
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Laptop doesnt boot when multi core processing is enabled
By multi core I assume you mean when enabling all of the true processor cores. In your laptop's case it's a Dual Core processor which means there are only 2 phyiscal cores and does not contain HyperThreading Technology (HT Technology) which enables "Virtual processor cores"
Could be caused by a couple of things:
1. Your processor doesn't support multi-core processing which is a possibility given there is no HT technology for your CPU. In which case there is nothing to fix. Even though the BIOS may have this option. You can check to see if both cores are enabled when you have multi-core processing disabled; In windows right click on your taskbar and click on "Task Manager" Click on the performance tab. You will want to count the number of processor displays you see. Refer to this to see what I mean:
The reason I have 8 CPU displays is because I'm running an i7-3820 CPU which supports HT Technology; So I have 4 physical processors cores and 4 virtual processors cores (created by HT Technology architecture)
2. You are running Core2Duo CPU with dual physical processors and have disabled 1 of the 2 cores because your laptop won't boot. This sounds more like you need to update the BIOS on the motherboard or maybe a bad CPU might be the cause as well.
Hope this helps.
Sep 12, 2013 | Toshiba Satellite M505-S4945 PC Notebook
Asus m4n78 pro no starting problem
check out power supply then cpu fan is running and video card works and ram is in all the way make sure that all the power plugs are in the right places as well on the board
Mar 15, 2013 | ASUS M4N78 PRO Motherboard & AMD Athlon II...
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
I want to upgrade my memory on Acer Aspire 7551
why do you need more memory your machine wont work better
Jan 03, 2018 | Acer Aspire One PC Notebook
No display even after the system boots
You either have a dead CPU or a dead motherboard or a partially-dead power-supply -- the power-supply should supply different voltages to different computers, i.e., one voltage to spin fans, and a different voltage to power the RAM, and a different voltage to power the motherboard. So, it can be "partially" dead.
Borrow a power-supply, and try that first.
If all else fails, take the computer to a qualified technician.
May 31, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
Apr 23, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
Intel DG965RY Motherboard Logo
208 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
