Question about Home
Thank you for reading this. I am a non-technical home owner. I have a Groge Atrio shower with a thermostat mixer in the wall. The water does not get hot enough so I need to adjust it upward. Do I remove handle from stem then faceplate at shower wall and then have access to the thermostat mixer? I suppose then there is an accessible adjustment valve where I can increase the relative hot water flow? thanks.
  • 760 Answers
You didn't mention what model you have. Here is a link to their web site. You can download a manual, that has detailed instructions on how to adjust. You should have a thermometer to measure water temperature to adjust properly. Go to : http://www.groheamerica.com You can identify your model, and then download the technical product information. Also check the temperature of other faucets in the house to be sure they are getting hot enough, and not a water heater temp problem.
Posted on Jul 13, 2010
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
Low hot water tempreture
Your question doesn't give me much to go on, but, If you have installed a new mixer valve in your shower and you can't get water that is hot enough to come out, there is a reason.
All newer mixer valves that I'm aware of have what's called a non-scholding setting that is done at the factory. ( I believe some manufacturers explain how to adjust this, in the paperwork you got with the part, if there are no children living in the home.) This is a child saftey feature, and if you want hoter water, you may have to raise the temperature setting in your water heater.
I hope this helps you.
Jan 29, 2011 | Home
My thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Very little cold water, lots of hot from kohler shower valve
Probably some pipe rust clogged the exit.
If u have pretty low pressure on one or both, hot and cold water, try keep force closed by hand the water exit at shower pipe, then start both cold and warm water gradually as much as u can keep it closed with the hand.
The pressure of the water will try "escape thru the clogged pipe and hopefully unlock that debris or rust!
The hot water pressure going back thru the cold water pipe might unclog that debris.
Just a simple fix which many times works as a charm..
Otherwise if this is not fixing, try close both water from main service valve.
Then unscrew the secondary shower valves and manually clean them or replace if very damaged.
Dec 14, 2017 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Nov 25, 2008 | Plumbing
Home Logo
114 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
