Question about Nokia 6300 Cellular Phone
Phone not charging
Don't know if the problem is the battery or the charger but there is no response when I plug my charger into my phone. Now it is completely dead and I can't get it on or to charge.
Buy a new battery and a new power supply also and you contact me i am the great technician of england thanks if its possile i am coming to mauritius on the 1st of may hope that we will meet i will stay at the sofitel hotel
Posted on Apr 20, 2008
How can I retrieve contact numbers from my fone that has discharged and wont charge
My phone died and now won't power on or charge. Here's how to fix it. Did your mobile phones battery drain all the way to zero and now your device is completely dead, not powering on or not even letting you charge it? This article will go through some tips on how you might be able to revive your dead phone.
If your cell phone is a smartphone then this is a reasonably common issue. It used to be a general practice to run older batteries to zero battery life before charging them back up to full again but try not to do that on the new smart phones, they use lithium-ion batteries which discharging 100% is a major concern and isn't good for the health of the battery.
If your battery has drained to zero and now the phone won't respond then try this
Pull the battery Start out by pulling the battery out of the phone for a few minutes then put the battery back into the phone, put the phone all back together and then plug it into your ORIGINAL charger that came with the phone. Make sure that you use the original charger that came with the phone. If you don't have the original charger then make sure that your charger is a manufacturer approved charger. If your battery is built into the phone and you cannot remove the battery from your smartphone then try to perform a simulated battery pull. Many phones have a method to restart the device, usually by holding down specific buttons or keys on the device. Much like the Motorola Atrix HD simulated battery pull or the Sony Experia simulated battery pull where you hold the volume down key and power key simultaneously while the phone is powered off.
Check the outlet Sometimes we can be too close to an issue and can overlook something as simple as a wall outlet attached to a light switch that's turned off. If the light switch is designed for turning off and on a light and the switch is off then there is no power coming from the outlet and obviously your device isn't going to charge.
Try a different outlet This can go hand in hand with the above suggestion. Try a different outlet to make sure it's not a power socket issue.
Try using a computer or car charger Using a computer or car charger instead of a wall charger can sometimes put a quick charge on your battery and get it to respond as well. Keep charging it If you have tried these methods and your phone isn't responsive due to its battery being drained 100% then it can be difficult to get your phone to charge again. Try charging it for at LEAST a couple hours on an outlet you know to be working, even all night if possible. Lithium ion batteries can take a while to get to charge again if drained all the way. So try charging it for a while, You might need a new battery If you try these tips and suggestions or have tried all these things already and there is still no response, and your phone is completely dead and will not recognize a charger then you might need to try another battery.
Try a different charger If you have tried a different battery then make sure you try your original charger first, as mentioned above. If there is no response then it might not be your battery but your charger that has malfunctioned and might need replacing. If you have any spare chargers try those to see if you can get a charge out of your phone. Replace the device If you have tried a different battery and a different charger and your phone is still little more than a paper weight then you should start reviewing your phone replacement
Sep 30, 2016 | Cell Phones
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
The battery will not charge even after i have plugged it up to a charger. i want to know how to get my phone to charge.
SEE IF THE CHARGER IS GOOD. IF IT IS FINE THEN YOU HAVE TO TAKE IT TO A MEC.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
I plug the charger in but there is no response of the battery being charged. Can anyone help?
I suggest you test your charger with another similar phone like yours, if it charges with another phone, it means the charging port of your phone is bad and need to be replaced.
But if it did not charge the similar phone like yours, it means the charger is bad and need to be replaced.
I wish you best of luck.
Feb 06, 2010 | Samsung SGH-X820 Phone
Samsung glyde - no response to charging
Find someone else with a glyde and ask them if you can trade them batteries for a day to see if it's a bad battery. ( you can usually buy a battery for $5 on ebay, or up to $20 in your carrier cell phone store)
If the problem follows your old battery, toss it and buy another battery.
And if neither swapping out the charger and the battert solve your problem then its the phone itself. I have called in to our cell companies before and let them know we have a phone that will not hold a charge no matter what battery or charger I use... and they usually replace free it under warranty as long as the phone is less than 12 months old, and the white squares in the battery compartment are still white. (Pink Red means oops! water got in there) and then you’re only getting them to cover replacement if you have cell phone insurance
Jan 07, 2010 | Samsung Glyde SCH-u940 Cellular Phone
Cell phone not responding to charger
This is not a fix per se, but if you feel it gets you a rock solid answer go ahead and rate it otherwise, please don't bother to rate this. I'm just giving your some guideance.
You phone in question needs replacement as there is a clear malfunction. You can call your provider or go to the phone store. You shouldn't have any problem having it replaced. They may even offer to upgrade you to a Razor or some such higher end model if its better than yours.
Best Regards,
Worldvet
Jun 17, 2008 | Samsung Cell Phones
The following
Hi how old is the charger often the wires inside the charge fray and short either try somebody elses charger or try you charger on someone elses phone if the charger is working ok then it could either be that the battery needs replacing or that the board is warped on the phone first of all i would try someone elses charger this way you kno the charger is working or not let me know how you get on ok
Dec 01, 2007 | Nokia N73 Cellular Phone
Will not charge at all
will the unit power off the two adapters. Ie when you remove the battery will it still power up? If it doesn't you have a bad charge jack. If it does you have a bad battery.
Oct 25, 2007 | Sony Ericsson T610
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
