Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I cannot watch one channel while recording from another.
I have a DMR-EZ48VEB recorder and a TX-26LMD70 TV.
I have to switch the recorder on in order to watch digital TV.
If I set a timer recording I take care to switch the recorder off when I've done so but have to switch it on again when I want to watch digital TV. If I'm watching a channel other than the one I've set to record, a warning notice appears, the TV is automatically switched to the recorded channel and I am unable to select any other channel until the recording is complete.
What am I doing wrong?
  • Panasonic Master
  • 736 Answers
You are not doing anything wrong. The unit is your tuner and it has to be tuned to the channel it is recording. You simply cannot tune to one channel whilst recording another. I see that others are having similar problems and that is the only one they tend to mention in reviews of this product.
" Downside is slow operation, plus using EPG exits programme you are viewing, but this won't matter if you have a digital tv, as you'd have two tuners to choose from - one (tv) to view and one to record from."
When we used to timer record on a VCR decades ago we would not be able to use it to tune a program for viewing at the same time and this is the same idea. We would have to use our television's tuner to view a different program. As the reviewer stated you would have to view a different program from a television having a digital tuner whilst recording on this unit.
Posted on Jul 13, 2010
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Recording and viewing different channels
The EX75 has only one tuner circuit, so you can't watch a different channel from the one you're recording. To do this you will either need a set-top box for Freeview or a Freeview compatible TV.
Apr 10, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is there a solution?
I have a similar setup. Your problem is because you are selecting the recording on the digital tuner of the TV. When you do this you need to keep the TV on and canot switch channel.
You should make sure you use the digital tuner on the DMR-EX77 recorder and then you can use the TV as you like.
Oct 09, 2007 | Panasonic DMR-E80H DVD Recorder
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
