Question about Frigidaire FAC126P1 wall/window Air Conditioner
A/c runs 1-2 hours then will not go back on for a day
My a/c unit runs for 1-2 hours then will shut off, it is not on energy save mode. It won't turn back on till the next day. What part is defective. Frigidaire brand
    Scholar:
  • 66 Answers
Sounds like the unit is shutting of on thermal protection. Try removing it from the sleeve and take it outside. Wash it out good with a garden hose. If the problem persists, there is likely a problem with the refrigerant.
Posted on Jul 14, 2010
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
Unit only runs when set to 1 cnt
unit runs If set to continuous mode only ? the other settings are a time off function that lets unit run only a portion of day , saves energy
Mar 01, 2014 | Kenmore 54501 Dehumidifier
Window ac unit shuts off when outside temp is lower then inside temp, doesn't help to turn down ' it still will turn off' its insulated all around very good and its new
It might have a "Green Feature", for lack of a better word. Does the unit still run the fan at all?
If the fan still runs without the compressor, then it is cooling in what they call economizer mode, basically uses the outside air to cool and save on energy.
That is my educated guess.
If you have a user manual for it, look to see if there is a energy saving feature to it.
Aug 19, 2013 | Heating & Cooling
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
Does it harm a refrigerator to plug/unplug it often?
Unplugging the unit is not required. Just turn it off with the control. Every time you turn it iff for an extended period of time and turn in it back on it has to pull temperature down which will use more energy than mornal for a short period. If it is being left off for more than a day you should see some savings but just turning it down to a warmer termperature (say a 1 or 2) then turning it back up to normal (say 3 to 5) will result in the same of not more savings (unless you are leaving it iff for more than two days at a time) and it will recover temperature faster (about 4 hours vs 8 hours). This will not harm the appliance over time.
Feb 07, 2010 | Marvel (6CAR) Refrigerator
GE (Mode TBX21ZLG) Frige has water collecting in bottom
if there is definite frost which has some depth to it, you may have a bad defrost timer. look for the timer usually inside kick plate in the front of unit. it'where you clean the condenser coils. with a flat head screwdriver or your finger turn the knob until the unit shuts off. if the fridge doesn't come on in 1/2 hour you have a bad timer motor and buy a defrost timer. if the unit comes on in 20 minutes or so the timer is good and you have to look elseware possibly the condenser coils and fan which are near the bottom clean coils anyway because it's good practice to keep them clean to save energy. the fan either works or it doesn't make sure refridgerator is running to check this. anything else you have to defrost the evaporater in the back wall of freezerthis could take some time but after it's defrosted turn timer to off a see if the heater is red in color if not then with a multi meter with the unit unplugged test across heater for continuity on heater . klixon and hi-temp cut out. good luck. if you are not feeling safe call a repairman
Dec 13, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Poor picture
Dynamic mode will give you a brighter picture. The energy saving mode runs the lamp at a more efficient level that saves energy at the cost of a slightly darker picture. Based upon your description, I'd guess that the lamp is nearing the end of its useful life. Plan on changing the lamp soon. When you do so, place the set back to standard mode and energy saving.
Dan
May 30, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Frigidaire FAC126P1 wall/window Air Conditioner Logo
115 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
