Question about Riso RZ390 Duplicator
Call service engineer code T14 just come up on my Riso GR3770 I am fairly conversant with my machine but I have not seen this before - can you help?
    Problem Solver:
  • 5 Answers
Try to hold both and press the M/L P/L button then turn on, u r entering the test mode of the mcahines,, then press 97 and start button.
Posted on Jul 27, 2010
    New Friend:
  • 34 Answers
This is a clamp error try fliping the clamp plate over and hit the reset. If that dosen't work make sure the magnet is in place on the rear arm of the clamp.
let me know if this dosen't work or if symptoms change.
Posted on Jul 16, 2010
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Jan 03, 2011 | Riso RZ220 Duplicator
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Paper tray will not lift on a GR3770
either the motor is not turning to lift it up or the gear is broken, do you hear the motor turning when the tray is pushed in? take the tray out and look in the back to see if there is anything blocking it also.
Sep 16, 2008 | Riso RZ220 Duplicator
560 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
