Question about Sony Ericsson K750i Cellular Phone
Help me my k750i is crash.it cannot be turn on for more than 10 second because it always keep restarting itself i cannot manage to master reset it because it keep turn off.if tehre any tricks to hard reset this phone like a few key press
  • 36 Answers
Hi
first pull out the memory stick then restrt the phone
it may hppen due to currpt file in your memory card
if problem is not solved by this then you have to need
reinstallation of your mobile softwere,problem will solved if
there is a no liqiud in yourhand set.
vyas
Posted on Apr 22, 2008
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
I have recently purchased the Garmin nuvi 765T and I have charged it and waited to use in the car but after a few seconds of turning it on, it turns itself off after showing the "Garmin" company...
Try to soft reset it by holding the power button for at least 20 seconds till it restarts.
If that doesn't help - try a master reset to factory defaults by holding the lower right corner during startup for at least 20 seconds. This will erase all user data and starts the Garmin in factory default.
If it restart I suggest updating the software to the latest version on Garmin.com
Jul 04, 2011 | Garmin nuvi 765T GPS Receiver
Full format sony ericcson k750i
Please open settings and select master reset at the bottom of the lists
Your mobile is now formatted
Thanx and i hope this helps
Please rate this solution
Jul 08, 2009 | Sony Ericsson K750i Cellular Phone
My phone keeps turning on and off
my pantech slate keeps restarting itself all the time...what can I do
May 19, 2009 | Pantech Slate Cell Phone
Sony ericson keep on crashing halfway through master reset
This phone support java compatible softwares, games etc.... it seems that you have installed a games which is not compatible with sony erricsson software. I would suggest you to remove the games which you have installed on your phone. Install only java supported games on your phone. After deleting if still your phone crashes update your phones software. This will resolve your issue
Apr 09, 2009 | Sony Ericsson K850i Mobile Phone
I have a sony ericsson w950i and it keeps resetting itself
you can do a master reset of it or just get the software reloaded or with the sony ericssons update utility update your phone
http://www.sonyericsson.com/cws/support/softwaredownloads/w950i?lc=en&cc=us
Mar 30, 2009 | Sony Ericsson W950 Cellular Phone
Phone keep turn itself off
try master restting it? hwo old is the battery? batterys have liek a one and a half year stadard life, if its older, get a new one
May 29, 2008 | Motorola Mobility V360 Cellular Phone
How to reformat k618i sony ericsson
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
Jan 03, 2008 | Sony Ericsson K750i Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
105 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
