Question about Ovens
No heat in oven
Hi, our belling electric oven has no heat, the fan still works so does the grill, I think it might be the heating element or the thermostat? is this an easy job to replace ? I think this oven is about 4-5 years old.
thanksin advance
  • 106 Answers
Check that tthe cable connection to the elements is ok and not burnt and that the power is at this terminal, if present then change the element and if absent then check and change the the thermosatrt
Posted on Jul 28, 2010
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Smeg oven
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
127 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
