Question about Braun 8585 Electric Shaver
How do I open a Braun 8585 shaver to replace the battery?
  • Braun Master
  • 1,623 Answers
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jul 13, 2010
Cytherian
  • 124 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
  • 164 Answers
SOURCE: how to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
Posted on Aug 29, 2009
  • 65 Answers
SOURCE: How do I open a Braun 8585 shaver to replace the
Look on the back of shaver and you will see the little rubber points on the body of shaver. Gently pry these out and with a decent small screwdriver you can then remove the screws to gently pry apart the shaver . You will have to remember how the parts fit together, but there is not that many . The batteries are soldered together and you will have to heat the solder to remove them.
Posted on Dec 04, 2009
brector3
  • 1623 Answers
SOURCE: Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Apr 08, 2010
Testimonial: "Fast turnaround on the response with an very easy to follow answer."
brector3
  • 1623 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
How to Reset Battery Braun 8585
You will find videos for dismantling the shaver as well as replacing the batteries at shaveroutlet.com. See link below for correct replacement battery type and videos
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
Mar 23, 2013 | Braun 8585 Electric Shaver
My braun 8585 needs new batteries. how do a change them.
You will find compatible batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for helpful tutorial videos
Jun 05, 2011 | Braun 8585 Electric Shaver
Hello. My Braun shaver 8585 model charges and the blue light comes on BUT whne shaving, it seems the motor dies quickly
This is a typical symptom of batteries that have passed their useful life. To restore the shaver to it's previous charging capabilities, you will need to replace the batteries. You will find correct battery type at shaveroutlet.com. See link below. You will need to order two
Scroll down item page for helpful video concerning installation
Jun 03, 2011 | Braun 8585 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
Jul 31, 2010 | Braun 8585 Electric Shaver
Apr 07, 2010 | Braun 8585 Electric Shaver
How to change batteries braun shaver ?
Aug 29, 2009 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
3,963 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
