Question about Archos Computers & Internet
THE DRIVE NEEDS TO BE CHECKED (RO) - Archos Computers & Internet
    Problem Solver:
  • 14 Answers
Just connect to a PC and run scandisk,but before you try that empty the cache and all temporary files, it may work.
Posted on May 20, 2009
  • danad1992 Mar 11, 2011
    I have run scan disk and repair disk several times, still receiving error message intermittently. What else can I do?
Wish ro remove mesagge " this disc is write protected" , so i can use usb memory!
Right click the drive and uncheck the read-only option. If there is a hardware switch, move it to the unlocked position.
Nov 03, 2012 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Tip
Installing Windows from flash drive-part I
I talked in a past “tips & tricks” about “How to quickly reinstall your operatingsystem”. I told you there about the time of the reinstallation. Now I bringyou a even quicker method. But. Of course there is a “but” here. The catch isabout the flash drive (pen drive, stick, USB flash, etc.), or should I sayabout the transfer speed and the capacity of the flash drive.
OK. The next question is: Why do I need a bootable stick?Here are some possible answers:
· You just bought an Acer Aspire One, or ToshibaNB200, or Asus EEE PC that hasn’t got any optical drive
· You do not have a optical drive on your computeror the one you have is broken
· Or you want to have a complete arsenal ofsoftware.
For making the bootable stick you will need thefollowing:
· A computer with Windows XP or Vista installed (Ihaven’t tested on Windows 7 yet)
· The installation CD of Windows (insert it intoyour optical drive and leave it there for the whole process)
· An USB flash. Preferably of 2-4 GB (depends on which version ofWindows you want to put) and with a high transfer rate.
· Download the following software:
Bootsect: http://storage0.dms.go4it.ro/media/2/84/1999/3124245/5/bootsect.zip
PeToUSB: http://storage0.dms.go4it.ro/media/2/84/1999/3124245/6/petousb-3-0-0-7.zip
USBPrep8: http://storage0.dms.go4it.ro/media/2/84/1999/3124245/7/usb_prep8.zip
Check Part II for the next steps. Because of the length issues I had to write a second tip
on Apr 16, 2010 | Computers & Internet
My RO light has changed from red to green. What does that mean? Red was the normal color.
Green is the color it should be when producing GOOD (low TDS) water. A constant Red light indicates the TDS is high (relative to what the normal TDS rejection is on your water supply) and the membrane needs to be replaced. Frequently the TDS light will be RED when initially drawing water at the RO faucet because of a spike of TDS coming through membrane from static water in line.
I suggest taking a sample of pretreated water and RO water to a dealer for a TDS test to see if the Membrane needs replacing.
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
I own an old Culligan RO system with a particulate filter, carbon filter, RO filter and post carbon filter all connected by tubes in an open environment. Replaced filters and tank is only 3-4 years old...
It is quite common to loose air pressure in the RO over time. At times the tank will be full of water but will not have enough air pressure to push water out. Take the tank of drain as much water as possible, for 3 gallon tank bring pressure in tank to 7psi, for 10 gallon tank pressure should be 10psi.
RJ
Mar 05, 2011 | Culligan Under Sink Water Filter
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
The projector comes up then runs for awhile then shuts down. I checked the fan and that seems to be ok. I also checked the capacitors and those are good as well. I have summarized the the ballast component...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector ro provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 20, 2010 | BenQ MP720p Multimedia Projector
Drivers burn
WORLDWIDE DISTRIBUTORS
country_left.gif Romania country_right.gifRomania - Sales & Technical Support Mackie sales and technical support in your area are managed by the distributor(s) listed below. They'll be happy to assist you with your support needs.
A.V. Audio Sys GENERAL CONTACT Str. Londra nr. 49 sector 1
011762 Bucuresti , Romania
Phone: +40 21 456 1765
Fax: +40 21 456 1765
Web: www.avaudiosys.ro
Stage Expert Ltd GENERAL CONTACT SOS.Oltenitei 251
Bucharest
Phone: 40 1 334 9924
Fax: 40 1 334 99 28
Web: stage@dnt.ro
Email: office@stage-expert.ro
Oct 31, 2008 | Mackie SRM-450 System
Computers & Internet Logo
629 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Computer Links
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
