Question about Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021)
Cd not working on my compaq laptop .spins then cuts out
  • 128 Answers
Hello there,
Now what I understand is that, you have the CD seated inside the drive and it starts rotating and then it stop's, Lets try the possible steps to get the issue resolved.
Now another important thing is that, you will need to check with another CD not a DVD to see if that works and based on what you have posted, we kind of come to a conclusion that it might be a problem with the Drive itself, so please check and see if it can read a CD, Once you are done performing the step try using a LENSE cleaner and see if that resolves the issue.
Now once you find that you DVD drive reads CD but not a DVD we can say that the hardware itself has a problem, However if it does not read any of the Disks then there is an issue with the lense and please use a lense cleaner as adviced. If not please check for the step's below to check the drivers.
Now the first thing is to check if the drivers for the device is workinf fine.
Go to my computer, which should be in start or you might have it on you r desktop aswell.
Right click on my computer, go to properties, and then in the hardware tab you will find device manager.
or
The easiest way is to use the run command, That is go to start- run- type- devmgmt.msc and key in ENTER, you should see device manager.
or
Right click on My computer- Click on manage- Then select device manager from the list of options you will see on the LHS( Left hand side).
Now Presuming we have reached Device Manager, The next step to be performed is to check if you have the CD/ DVD drive working effitiently or not, How we can do it is by following the step's below:
Go to Disk drivers on to the right hand side of the window and expand disk drivers and check if it has a yellow or a black exclamatory mark on it, Well if it does,
Go to ACTION and scan for hardware changes, Result will indicate what exactly is the problem.
Most of the time it is never a problem with the drivers for CD/ DVD drive but still no harm in checking for it as a last option.
Posted on Jul 22, 2010
Cd player will not come on or eject.
check the power oin to the cd rom for loose contact remove the power pin and insert it with other one place ur hand on the cd drive feel wether the drive is spinning if its spinning click the eject button if not take a long neddle and you will see a small hole in the front of the drive insert the needle in it and press the cd drive will eject try to close the tray using the button and if not working you have complaint with the drive
Oct 14, 2010 | Compaq Computers & Internet
My cd drive is being funny. whenever i insert a cd it spins like crazy making a loud noise...
u got ur cd rom damaged....
it has dirt inside it
clean the inner layer of ur cd rom
apply lubricants if u can
if not
take it to a computer store to repair it
Mar 12, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq laptop CD-Rom has power, but is not recognized by system
to resolve this problem remove the disk from the drive,then click on run and type regedit and you will see registry editior and follow the path bellow
HKEY_LOCAL_MACHINE\system
\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and you will find upper filter and lower filter on right hand side panel you need to delete them bothe one by one and restart the system anda chk if it works
Sep 18, 2009 | Compaq Evo N610C Notebook
Compaq 701tu cd drive does not spin
check if the green light comes on when you insert a disk,if no?
1. switch off the pc,
2. open the case cover
3. check the power cable is connected to the device"compaq 701tu cd drive"
4. if still not working
5.try other cd device and if that work,it means your compaq 701tu cd drive is faulty and to be replace.
Jul 31, 2009 | Sony CDU 701 (CDU701-10) Internal 32x...
No cd player on my lap top
Sounds like the cd rom is faulty,the little motor that spins the disc could be faulty or voltage driving it is cut off due to a electrical component failure.You can open the unit and with the cd tray open look for a tiny microswith at the rear or font around the tray that activates power to the motor when the cd draw closes,it may be dirty but and need a bit of lubricant to free it up but most likely it's the motor.
Jun 25, 2009 | Compaq Evo N610C Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Jan 15, 2009 | Compaq Presario R3000 Notebook
Compact laptop keeps overheating then cutting off
Check the fan, it may have stopped spinning. If the fan bearing has seized, you may be able to free it by removing the fan label covering the bearing and oiling it. If it does't work, replace it.
If the fans spins freely then remove the fan and clear dust from the heat sink fins.
Dec 12, 2008 | HP Compaq Presario 1500US (470038-813) PC...
Help- CD Rom works sometimes
all you need to do is just have CD-ROM replace , they're cheap and easy to get , ebay selling it , not too hard to install it either .
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
