Question about Ryobi 18-inch Electric Chainsaw Chain Saws
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and prevented from reoccurring. Thanks. Pat.
    Brigadier General:
  • 4,088 Answers
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Posted on Jul 13, 2010
PCN 4545 Ryobi won't idle.. adjusting the Low/Hi and the Throttle screws did not make any difference.
I trawled the web for answers but all the checks mentioned did not apply to me.
Inoticed that the throttle screw was unable to do its job- This was because the wire (looks like bicycle brake wire) that goes from the throttle trigger on the handle to the carburettor assy was to short about 2-3mm.. over time..(maybe because the chassis has expanded over time or the handle has moved away from the main chassis body by about 2-3mm short over time.
The throttle trigger cable being about 3mm short over time prevented the throttle from closing in far enough to make the chainsaw idle/or to engage(touch) the throttle screw to make the adjustment viable.
I opened the trigger handle assy (3 screws).
I took about 4mm of the outer black plastic covering off the trigger wire cable, exposing more of the inner wire. this allowed more of the inner wire to get to the throttle end (add slack).
I reassembled and can now adjust the throttle correctly using the screw to make the Chainsaw idle.
hoorah!
sal
Posted on Oct 01, 2015
Chainsaw want idle why?
Try adjusting the idle 5crew on the carb. Its usually marked with an [ I ]
To get it just right, make sure your chain brake is off, screw in the idle 5crew, the saw will rev and the chain will start to turn. Now back the idle off until the chain stops moving and the engine is ticking over nicely.
May 04, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
Need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Oct 26, 2011 | Garden
PCN 4545 Chainsaw I unfortunately used unleaded petrol instead of 2 stroke, now can not get saw to start, is it game over for carberette?
Hi, it won't affect the carby which I'm afraid is the only good news. It will need a new piston and probably a cylinder. Depending on the price of these parts to suit your model it may not be worth repairing. Sorry Phil.
Jun 20, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
My craftsman chainsaw is pretty new, and it isn't starting properly. When it does start, it has a tendency to cut out during use. I adjusted the idle time, a few times, cleaned the air filter, and checked...
There will be three screws on the carb, the tick over screw, a L screw which ajust the mixture from idle to half throttle, ans a H screw which adjusts the fuel running speed, they are both fuel screws not air screws, start with a basic settinf of one and a half turns on each from closed, with the saw idling gently screw the L screw in, the revs will start to increse as the mixture weakens off, it will reach a point where it starts to die, at this point start unscrewing the L screw, the revs will increse again and then start to die because its too rich, now turn it in 10 minutes on a clock face, check that it revs cleanly,adjust the idle screw so as the chain does not rotate around the bar, the H screw controls the max rpm, this should be set with a rev counter, it should not exceed 12500rpm
Apr 21, 2011 | Garden
Engine dies upon acceleration after starting and idling
turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
Jul 02, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Ryobi chainsaw PCN 4545 overheated
Sawdust/dirt build-up helps cause this situation. Usually, the band is deformed so that it drags. The melted case parts may or may not need replacement, but will likely need trimming. The band usually does as it is difficult to remove the small bends in it. After repair, make sure the chain turns freely by hand. Set and reset the brake several times to make sure it works correctly. The clutch outer drum rarely deforms when this happens. Hope this helps!
Jun 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Hi, I have a Ryobi PCN 4545 petrol Chainsaw that i have owned for about 4 years with little use. I went on a Chainsaw users course over the weekend and took the saw on the instructors recommendation....
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/PCN-4545-_E
You probably don't want to hear this, but there have been many many problems with this unit. It is now, discontinued, Personally, I would get another one, any other one. To have any chance of any type of repair, you must get a service and repair manual. I have searched extensively but have been unable to find any manuals other than the User, one supplied.
http://www.shouldersofshoreham.co.uk/sos_17Bamp.mvc?P=pcn-4545
Above is an exploded parts diagram, that should be of some help.
May 25, 2010 | Garden
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
682 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
