Question about Acer Aspire 3680 Laptop
Charger not charging cord at pc heated up then didnt charge battery.
  • 41 Answers
Try to buy a new cord to be safety. i think your cord is in grounded and short inside.
Posted on Jul 13, 2010
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
My battery wont charge but it says its charging. When I unplug the cord 3 times itll go up by 1%
Have you tried replacing the battery? It sounds like the charger circuit is attempting to charge the battery and the battery is not accepting the charge.
Jul 19, 2012 | Sony Computers & Internet
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Battery charger
Yes. Usually they either work or they don't so obviously when they test good they should charge the battery. Dell laptops have a "data pin" that determines what wattage of power cord is plugged. If this data pin goes bad on the power cord or motherboard the laptop won't charge.
May 03, 2010 | Compaq Presario Notebook
Bought a new battery (larger one) and it will only charge for 1 second?
Check if the battery is already fully charged. If it is, the charger will stop charging when battery is 100% charged.
You can check this by unplugging the charger cord from the laptop. If the battery is not fully charged, plug in the charger cord into the laptop again, start the computer and enter the BIOS. In the BIOS, look to see if you have a "battery check" and start it. This will test the charging and discharging cycles of the battery.
Mar 22, 2010 | IBM ThinkPad R50e Notebook
BATTERY IS BAD. CHARGE CORD HEATS UP. REPLACED CORD AND CHARGER LAST YEAR
Compaq chargers get heated up a lot when charging. This is a common problem.
Based on the issues you mentioned, unfortunately you would need to get the battery changed.
Regarding the charge cord getting heated up, try keeping it on a concrete/cold surface to lessen the heat. Unfortunately nothing more can be done about it, and as i said compaq chargers do get heated up quickly.
Thanks.
Feb 03, 2010 | Compaq Presario M2000 Notebook
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
Jazz dv179
I'm sorry the charger was missing from the box. Please contact us at 732-572-7050 to replace the missing parts.
Thanks,
Sheryl
Jazz Products, LLC
Dec 04, 2008 | Jazz DV-179 Digital Camera
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Does not turn on
There are some known issues with the included charging equipment. Personally, I ordered a relatively inexpensive charger from Amazon.com that works wonderfully. All you really need is a device that turns a standard wall plug into a USB charger. You can then plug your base that the ipaq stands on into that and it should begin charging. The old battery is probably dead (mine was), but try to charge it anyway.
Note: The actual cord that came with my charger DID NOT WORK. It is sitting in a box somewhere, and if its the same thing I had (it probably is), then you just need the wall-to-USB converter.
This is what I bought:
http://www.amazon.com/iPAQ-rx3715-Sync-Charge-Cable/dp/B000DT8F0A/ref=sr_1_4?ie=UTF8&s=electronics&qid=1204335733&sr=8-4
It is only $10. Again, the cord didnt work for me. Maybe it will for you, but if you manage to find just that converter for less money, more power to you!
Feb 14, 2008 | HP iPAQ RX3715 Pocket PC
Acer Aspire 3680 Laptop Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
