Activate touchchip fingerprint coprocessor - Computers & Internet
Do you have have protector suite QL in your programme list? its the software to set up your records and manage personal security - then it will work each time you swipe your finger.
Posted on Apr 20, 2008
What is the activation code for my fingerprint?
There is no such thing as an "activation code" for your fingerprint. The computer on a boimetric fingerprint scanner collects the information and creates a digitial signature code for your finger. It is unique to you and you only.
Nov 09, 2013 | Computers & Internet
Finger print
Good question. First off, I would never use a fingerprint reader for security anyways. They send your fingerprints off to the feds when you sign up (by force) to use that reader. Ask someone else if you weren't quite ummm... if you made the mistake of using that device. (Yes my laptop has one and no I never activated it as it was pointless) Maybe another tech can help you that has used that before.
May 29, 2013 | Toshiba Satellite Pro U400-S1001V Notebook...
Finger print enrollment
The security software should have been installed at Toshiba. If not it is easy to download and install. You should have a biometric coprocessor driver which runs the scanner. That sounds like what is missing. If you had to reinstall windows this may not have been put back in.
To get the drivers go to www.toshiba.com and then click on support.-mobile computing - drivers download. This pops up a new window that you now have to click on what model you have. I have a Tecra A8 201E so I click on notebook in the left, Tecra, then A8 and then on 201E then click on the go button. You should filter by operating system so you are only looking at the right drivers. There are three downloads for the security. One will be called HDD security, TPS Trusted Platform Security, and Fingerprint software. If you download those and save to your desktop then you can easily run then as needed. When you have them run the one called fingerprint software. That should install the scanner drivers and may be all that you need. Try running it after installing this. Make sure your backup password is something you can remember. If your scanner fails and you can't remember that then you can get locked out of your computer.
The TPS provides some other tools such as a 'safe' that saves files in an encrypted area. You can disable it if it inteferes too much.
The HDD utility locks the hard drive which can stop people from using your computer as they won't have your fingerprint to unlock the drive.
Apr 27, 2010 | Toshiba Fingerprint Reader
My computer is not recognized as a sony vaio vgnt37gp
Vaio is tricky to get working right,,
you must install in this order!!!!!
  1. BIOS update (if available)
  2. Intel® Chipset (if applicable)
  3. Microsoft KB896256 (Mobile Dual Core) (only available on some models, please verify with Sony Support web site http://www.sony.com/pcsupport)
  4. Microsoft KB909667 (System stops responding during standby, hibernate or shutdown.) (only available on some models, please verify with Sony Support web site http://www.sony.com/pcsupport)
  5. Sony Notebook Control (if applicable)
  6. Sony Programmable I/O (if applicable)
  7. Sony Shared Library
  8. Video NOTE: On some newer VAIO PC models, the system will support two different graphics hardware. The setting mode is identified as:
    1. Stamina: Intel Graphic mode
    2. Speed: Nvidia® Graphic mode
  9. Audio
  10. Modem
  11. Network
  12. Camera
  13. Wireless
  14. MPEG Encoder
  15. Multi Card reader (if applicable)
  16. Flash Media (if applicable)
  17. Flash Media registry
  18. Memory Stick® media
  19. Memory Stick Registry
  20. Bluetooth® Registry (if applicable)
  21. UPEK TouchChip Fingerprint Coprocessor
  22. Infineon® Trusted Platform Module
  23. Wireless Keyboard and Mouse utility
  24. SmartWi™ Utility
  25. Cingular Connection Utility
  26. WWAN driver
  27. Any other Sony Utilities NOTE: Will be explained in the software dependency section
  28. Hard drive protection
  29. Toshiba Bluetooth application
Feb 26, 2010 | Sony VAIO VGN-T370P/L Notebook
I disabled my fingerprint sensor, how can i activate it again? appreciate your support
Dear sir,
If you are diabled fingerprint sensor in BIOS,go to the bios enable finger print sensor.
If you are disabled fingerprint sensor in windows.
Enable it in device manager of control panel.
Aug 08, 2009 | Acer Aspire 5720-6661 Notebook PC
Please help me im just a begginer just want to de activate my acer finger print authentication or change to another settings
Look in Start Menu > Control Panel for a protection software for your fingerprint scanner. There should be a built-in software to your operating system that controls settings for the device. There, you should be able to activate/deactivate it or alter settings to your liking.
You could also try going to Control Panel > System > Hardware > Device Manager. Click on Biometric and disable the "touchchip fingerprint coprocessor".
Let me know if this helps!
Aug 04, 2009 | Acer Aspire 5720-6661 Notebook PC
I have a toshiba a105 s4114...i need to know how to i lock my computer using my fingerprint
Use your System Restore DVD's to activate the Fingerprint Reader; once activated, you will have to register your fingerprint(s) and then you can sign in and/or lock your laptop with your fingerprint.
Jan 19, 2009 | Computers & Internet
Computers & Internet Logo
749 people viewed this question
David Payne
David Payne
