Question about Samsung SCX-5530FN Laser Printer
Hi we are having a problem over heat error recycle
Hi we are having a problem, over heat error recycle power, which we have been doing for a few weeks, This appeared to work but now it just makes a grating/rasping sound. Help please.
  • 222 Answers
this sounds like you have fuser problems
UFR gear is brocken or something
Just visit authorised service, technicians will resolve your problem
Posted on Jul 14, 2010
How to cycle the power on a Samsung CP610ND?
Pull out the plug, wait five minutes, replace plug and switch on.
Jan 07, 2014 | Samsung CLP-610ND Color Network Laser...
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Office Equipment & Supplies
Heat not woking purge light flashing
The flashing light is giving you a code as to what is work... have you tried to recycle the power???
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jan 15, 2011 | Honeywell Electronic Programmable...
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a error message on my Lexmark C510 printer that reads: Invalid Engine Code. The printer will not print. Any suggestions
Recycle the power a few times, if that doesn't work first reflash the engine firmware (you would need to contact Lexmark for that) failing that replace the engine board.
Apr 23, 2009 | Lexmark C510 Laser Printer
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Enjoy.
tnx
-micro
Feb 10, 2008 | Computers & Internet
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Sep 15, 2005 | NEC MobilePro 770
Samsung SCX-5530FN Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
