Question about Garden
I have a Heath Zenith SL-7001-WH-C 180-Degree Solar Powered Motion Security Light with Halogen Bulb White. Can you tell me the voltage watts and amps output of the solar panel?
5 Suggested Answers
fisherman816
  • 66 Answers
SOURCE: How do I replace the Halogen bulb on the Heath
Unscrew the bulbs counterclockwise with youre finger tips.
Posted on Nov 13, 2009
  • 3074 Answers
SOURCE: have a black wire coming
where the battery clips in the one without the spring
Posted on Mar 04, 2011
SOURCE: we bought a solar light
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Posted on Jun 25, 2011
joeguest2
  • 2080 Answers
SOURCE: I bought a solar motion
If you could provide a MODEL NUMBER for your security light, I could certainly find a detailed set of instructions for you. However without that Make or Model Number, I can only provide you with some general information.
Here is a link to a general description of a Maxsa brand of Solar Motion Sensor Light:
http://www.maxsainnovations.com/products/40220.htm
And here is a link to the User's Manual with operating instructions for a Maxsa light (model 40110):
http://www.smarthome.com/manuals/71862.pdf
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
If you are unable to find a model number for your light, even a detailed description of the various control buttons on your particular unit would be of some help.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much, good luck, and take care.
Joe.
Posted on Aug 02, 2011
Defiant 270 Degree White Replacement Motion Sensor manual
i ave a live switch leg no switch wil sensor function correctly or will it always stay on?
Oct 17, 2013 | Heath Zenith 270 Degree Replacement Motion...
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
Oct 15, 2013 | Heath Zenith Heath/Zenith SL-5411-WH Heath...
Light does not shut off
I have had a lot of problems with this model of sensor. I bought 6 a few months ago and they all are bad. I have since switch to a different model sl-5315-wh-a and all seems good again. I got them from Lowes. I think that they were around $23 each. I have been using these type sensors on my house for 20 years and have replaced them all at least 2 times.
Hope this helps
Feb 03, 2011 | Heath Zenith 270 Degree Replacement Motion...
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
My sensor no longer works. It use to turn on the porch light when someone entered the carporch. How do I open the sensor so that I can put new batteries in it? I know that it uses AAA batteries.
Manual for this sensor is not available.
In the Zenith I have installed The motion sensor battery slot was h at the back side of the sensor, you had to remove the sensor from the wall sliding it on one side to access the battery. It mounted two AA batteries, not AAA.
Aug 17, 2010 | Heath Zenith 270 Degree Replacement Motion...
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
