Codemasters Hospital Tycoon for PC (40153) Logo
Posted on Jul 13, 2010
Stat fax 4500 filter voltages -low error - Codemasters Hospital Tycoon for PC (40153)
waadyoussefs
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 15, 2012
waadyoussefs
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
245
Points
Contenouse pump aspiration
1helpful
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
My American Standard Acculink a/c is not working...it has Error 126 displayed on the screen. I went outside and switched the circuit breaker switches on and off but nothing happened. What does Error 126...
If the indoor fan is working but outdoor unit is not on check for low voltage to contactor, no voltage check for continuity of t-stat wire, with low voltage test outdoor unit components
My carrier AC(model: Optima D plus) is displaying a error "E3". Can someone suggest a solution to it.
An E3 error on your thermostat (T-Stat) has the following description from your manual:
"Brownout condition or too low of voltage to thermostat. Double check wiring and check for
24 vac between R and C. E2 will clear 15 sec after proper voltage is restored."
If you are unsure how to check the low voltage to your t-stat, then please call a professional in your area to check the t-stat wiring and the transformer in your furnace.
I have a 5 ton air conditioner made by international comfort corporation, it bears the model number PAB036N1LA and I need to know what the diagram is to hook up the thermostat. its a commercial rooftop...
on the unit it should have low voltage termanals labled R Y G H H2 the R termanal goes to the t-stat on the r termanal and the y to y on the t stat ang g to the g on the t stat and H termanal goes to h on the t stat etc if thers no termanal block find the low voltage wires and get back with me on the collors
2answers
Error 41
Error 41 -The head drive voltage has not been turned from Low to High within the specified time.
Check:
• Carriage ASSY
• Main PCB
• Print head unit
• Power supply PCB
Hope i helped you.
Thanks for using 'Fixya'.
1helpful
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
3helpful
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Error 77
related to a fuser error. Unit is detecting a too high or low heat internally. Try turning off for a few minutes. If error returns check voltage level at outlet or try a different outlet. Maybe too many items plugged in same outlet. If error returns, may need new fuser or thermistor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Codemasters Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Codemasters Computer and Internet Expert? Answer questions, earn points and help others
