Question about Kodak EASYSHARE 5100 All-In-One Printer
I am looking for drivers for my Kodak All in one 5100 printer/scanner . I have windows 7 64 bit os. Could you please help . Thanks
SOURCE: Cannot find a default setting for scanner
by chance, is that printer plugged into a power strip? that can make a scanner NOT work.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
SOURCE: Kodak EasyShare 5100 All-in-one printer will not print ink
you most likely need to run a head clean and alignment, which is needed after each cartridge replacement.
  • 130 Answers
SOURCE: Kodak Easyshare 5300 printer drivers doesn't have Home Center
Re-download from here:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540&operatingSystem=mac_os_x_10_5_x
Make sure you download the "KODAK All-in-One Printer Software (including drivers) for all 5000-Series and ESP-Series Printers" and not the "firmware".
Select to install all drivers (should be the default). Reattach the Kodak.
Posted on May 03, 2009
tbock86
  • 68 Answers
SOURCE: I cant get kodak 5100 drivers to install
If they do not have a driver on the website specifically for Windows Vista, you could try a Windows XP driver and see if it is compatible. If not, you will not be able to use the printer without the specific Driver software. Hope this helps.
Posted on May 09, 2009
Neerak21
  • 101 Answers
SOURCE: The scanner does not work on my Kodak EasyShare
Hi, if nothing happens when scanning w/ your printer.Please follow the steps below.
1.Verify that the scanner is working properly by copying a document first.
2. Open the Kodak AiO Home Center software.
3. Select Configure Settings.
4. Click Scan.
5. Click either the Documenttab or PictureTab depending on the file you want to scan.
6. Under File Save Setting, sure that the Prompt for filename and location is selected.
7. Click Apply then OK.
Thanks.
Regards,
Neerak21
Posted on Sep 24, 2009
Lost install cd for my kodak all in one 5100 scanner printer coppier what should i do
Go to the Kodak website and look for "support" or drivers and download the drivers for your model from there.
Mar 09, 2013 | Kodak EASYSHARE 5100 All-In-One Printer
I am able to print again but cannot scan . Can someone help me ? I have the disc and have uninstalled and re installed the program...
Since you have a USB connection, try a new USB cable or connecting to a different USB port. Make sure that you have the Epson utilities and drivers for your version of Windows 7 installed. (To check if you have the 32-bit or 64-bit OS, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise it's the 32-bit version.) You can find the drivers for printers from Epson.com. Click on the Drivers and Downloads tab at the top of the page. Then select your printer. (I've seen two versions of your request - one listed the printer as the ESP 3 and another added it was the 310. The only 310 all-in-one that I was listed at Epson was the Workforce 310. Please clarify this.)
If you installed a generic OS driver, you may only have a printer driver. Unplug your USB cable and uninstall this generic driver before attempting to install the Epson software. To launch scans by pressing the buttons on the scanner, you will need the Epson monitoring software running and the destinations for the buttons set up. Start your scans from your computer first.
Windows Fax and Scan and Paint are included in the Windows 7 software (except in the Starter version) and will acquire scans if the scanner driver is installed. Fax and Scan: New Scan. Paint: File > Import from Scanner or Camera > New Scan. Photo Gallery in the Windows Live software can also acquire scans. Trying one of these alternatives may give a better idea of what your error is.
Windows may not think a scanner is installed or a communication issue may be at fault.
I hope this helps.
I hope this helps.
Oct 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I want install Kodak 5100 aio PRINTER
1. if you have CD came with printer, please keep in the cd rom and goto my computer -> cd driver-> double clik setup.exe. and follow the instructions.
Otherwise. ....
2.
Please download the files from http://support.en.kodak.co.in/app/answers/detail/a_id/36555/selected/true
and follow instructions
Installation Instructions
  1. Verify that your computer meets the system requirements.
    note.gif WINDOWS XP 64-bit Operating System is not supported.
  2. Disconnect your all-in-one printer from your computer.
  3. Verify that you logged on to the computer using the administrator account.
  4. Close all programs.
  5. Download the software onto your computer.
  6. Double-click the *.exe file, then follow the on-screen instructions.
  7. When the installation is complete, connect your all-in-one printer to your computer.
  8. Select Start > Programs > Kodak > Kodak AiO Home Center.
Hope this helps to yoy
Jun 18, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
CANT GET MY 5100 TO PRINT ON MY WINDOWS 7
I would suggest you check to make sure you have updated drivers for Windows 7. If you don;t uninsatll your current driver; download the updated driver and install. Driver available here:
http://wwwcaen.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9098/9099&product=EKN033539
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
I have just purchased an new computer and am running windows7 on a 64bit machine. I have tried several times to install the Kodak software from the disk provided with my printer which worked OK on my last...
32 bit and 64 bit drivers are not compatible. So for 64 bit operational system you have to install 64 bit drivers for your Kodak Easyshare 5100. I found link for you:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
I am strongly suggesting uninstall everything what are you installed ignoring warnings about incopatibility before installing proper drivers! Good luck! :-)
Sep 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Hi can you help me with a Kodak printer question ? Running windows 7 is there a new driver ?? I am also running on a 64 bit laptop does that make any diffrence |??
Yes there is please visit kodak.com/go/downloads. Now just click the selection and choose the model of your printer for you to download the latest software and drivers for all in printer., It doesnt matter if your using 64bit or 120 bit.,
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
May 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot download or install kodak esp3 aio drivers or software
either you have 64 bit op system or you dowmloaded the wrong driver on accident.
if this information helps please use fixa when rating. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jul 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
126 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
