Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Motor keeps triping in
The motor keeps on tripping in on my saniflo top toilet when not in use. Could you help me solve this problem?
Regards,
Colm
    Problem Solver:
  • 8 Answers
If the pump is tripping the GFI then could be a broken pressure chamber, which is were all the electrical components are and if it senses water it will trip the GFI. Solution will be to replace pressure chamber complete.
If the pump is turning on by itself then water could be draining back into the pump. Either the flapper inside the toilet tank is leaking water or the check valve on the discharge elbow is not closing all the way. Solution will be to inspect flapper on flush valve (inside toilet tank) or may need to be replaced. Also the flapper on the check valve must be inspected for obstructions of may need to be replaced.
Posted on Jul 20, 2010
Saniflo keeps tripping the breaker
It sounds as if there is a fault with the macerator motor. Are you saying that the saniflo is causing the rcd / fuse to trip, so you reset it, and it trips out again? Can you hear any noise from the saniflo before it trips out? If not or there is a loud humming noise it could mean the unit is blocked and the motor has stalled. Can you detect any unwanted smells coming from the unit? if so there is a good chance that there is a leak which may have strayed into the internal wiring and tripped the supply.
Jan 10, 2015 | Saniflo Home
I just bought a new house and the saniflo toilet is fairly loud. is there something that I can put in it to clean it out.
If the unit is making a loud noise then there could be an obstruction in the blade or impeller, you will have to pry open the lid using a flat head screwdriver and then remove the motor out of the casing, the blade is on top of the motor and the impeller is at the bottom of the motor.
Saniflo recommends using any cleaning products that does not contains bleach or chlorine such as liquid lysol, Mr. clean or simple green. Also Saniflo sells a descaler that is designed to clean the inside of pump casing.
Jul 12, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
NOISY SANIFLO
Always an issue, guessing it is on a tiled floor? or up against a tiled wall?
I put some thin foam / Bubble wrap underneath and behind mine to dampen the vibrations. It also helps if you box the unit in and use foam to quieten the noise (on top and around the unit). Depending upon how long you have had it, it may also need a clean out or possibly even the motor bearings are getting a bit worn, creating some noise with the excess movement.
Good Luck
Jan 07, 2010 | Saniflo SaniPlus-Elongated SaniPlus...
It is blocked how do i unblock it
Turn off electricity to saniflo.Turn off water to toilet (normally an inline valve). Empty toilet bowl and cistern of water. Remove toilet, cistern. Disconnect inlet pipes to saniflo (careful as backed up water will flow out!).
Take out Saniflo (outside is normally good). Open up top with star driver and use a flat blade for the plastic retaining flaps.Be sure to wear rubber gloves to keep out germs from cuts etc on your hands.
Cover mains cables with plastic food bag and tape up. Use a solution of bleach / warm water, fill up the sanifo and leave for a while. Swish around and empty into a drain etc. I also use a hosepipe to make sure I get it really clean (esp under motor and float switch). Also check inlet pipe flappy bit and the actual pipes that connect to the saniflo
Good luck
Dec 19, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Helicopter starting :)
could be the thermal trip on the motor. Suggest you remove the lid and clean out any buildups inside. check for for a jam,around the blades like a tampon. Careful - they are very sharp!
Oct 01, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
407 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
