SOURCE: change language'
Press the center button... that is the menu button.. the highlighted one would be the gallery.. Gallery is the one that looks like a reel with a music note... from there press the left direction key once... this should be settings... this icon looks like a spanner.. press center key to select this...now from this new menu scroll down n select the one that looks like a phone with a spanner... use the down key to scroll.... on the 'Phone with the spanner' icon perss the center key.. The first option is always Language menu so press the center key on the first option... if all was correct you will get another menu in which again press the center key at the first option... Now if luck supports you, you will see a list of languages from which select ENGLISH {It will be in English :-)}...n voila
Lemme know how it works out mate
SOURCE: How can I change the phone language on my Nokia 5000?
dude this happened to me 1ce.........first find a frnd or sum1 who has the same phone(wit english).......then use his\her menu to help u navigate....the crotian system is the same as the english 1 so all u gotta do is match it.....this worked for me..........if not u will hav to use the google translator to fix ur prob..
HOPE THAT HELPED....:D
Hi let me give you a hint.First try to Open Menu >> Setting by following the symbol >>Open Phone setting by following the symbol>>> inside the you'll see English.....Good luck
