Question about Xerox WorkCentre M128 Copier
I am getting a fault code 116-353 and the machine is asking to switch it off
  • 33 Answers
On the back side of copier there is a door/hatch. Udet the hatch there is the processor board with DDR DIMM memory. Pull it out and put back again. Procedure is the same as if you were putting DDR dims on a pc motherboard- so follow electroctatic precautions. Ground yourself first or use a grounded wrist strap.
Posted on Sep 08, 2010
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
What does the fault code e2 mean?
Kenmore e2 code Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > e2 code > Washing Machines
Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
Jul 26, 2015 | Washing Machines
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
How do i reset a dryer display when i get the fault code F 06 on this machine Whirlpool AZB8670 ??
it's not normal for this to happen but you might have to get someone with a computer to reset it for you ask an engineer to check for you
Jan 03, 2015 | Whirlpool Washing Machines
Does tcm store fault codes on 98 pathfinder and if so how are they erased?
You would take your vehicle into a auto electrician and ask the electrician to hook up a computer system to check for a fault with your vehicle computer system he should give u a fault dynostic apprasial on the spot
Nov 23, 2014 | Cars & Trucks
Machine says "I need service"
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Symbol of an engine picture on dash? 2003 Golf
That is the engine management computer telling you that a fault has occured and you should get the car onto a diagnostic computer asap to check what the fault is.Diagnostic machines only give you the fault codes NOT the fault.so when youve checked it out get back with the codes so that we can give you itemised fault remedies.(as the machine is quiet expensive,i sometimes suggest that you get a diagnostic done at a dealer,then ask for advice,its easier.and cheaper.)
Dec 08, 2010 | Volkswagen Golf Cars & Trucks
When I switch machine on I get a P3 code
Use this link to check for the make of the washing machine you are using.to get fault code and solution.
(http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html).
Aug 04, 2010 | Washing Machines
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Xerox WorkCentre M128 Copier Logo
1,767 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
