Question about Nintendo Wii Console
51330 wont connect to wireless internet it knows its there but wont connect
  • 218 Answers
Check your connection settings.
Posted on Jul 16, 2010
  • 12 Answers
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
Posted on Nov 16, 2009
fliiskater11
  • 53 Answers
SOURCE: wii wireless connection error 51330
get a new router
Posted on Feb 07, 2010
  • 1234 Answers
SOURCE: can not connect to the internet error code 51330
Error Code: 51330This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 26, 2010
  • 71 Answers
SOURCE: error code 51330 trying 2 connect 2 internet by
Hello!
The usual cause of error code 51330 appears to be that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
This is how to fix it:
Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
If this does not work, I would suggest doing a power cycle of your modem and router. This is done by following these steps:
  • Unplug both the modem and the router from the power outlet.
  • Wait a few minutes, and plug the modem back in.
  • Wait a couple of minutes for the modem to initialize, then plug in the router.
  • Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response
Posted on Jun 15, 2011
  • 16 Answers
SOURCE: I am trying to connect Netflix to my Wii and I
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Posted on Jul 21, 2011
Trying to connect to the internet through Wii but getting error messgae # 51330
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings.
WEP AND WPA Security keys are case sensitive.
Aug 28, 2011 | Computers & Internet
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Jul 21, 2011 | Nintendo Wii Console
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
Error code 51330
The error code 51330 means that your Wii cannot connect to the internet through your wireless connection.
It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow so m
Jul 17, 2011 | Nintendo Wii Console
Error code 51330 unable to connect to the internet choose internet setting and then confirm your connection then it is tellin me to vist this sit i am wondering cam u help
The error 51330 normally means that the password or WEP key you entered to connect to the internet through the Wii did not match the one the wireless router needs to allow connection.
If you don't know the password, check to bottom of your router, it will usually have a sticker on the bottom with the standard password on it. This can also be marked as WEP key or WPA key. Enter that password exactly as it appears there, as it is case sensitive. If the password is correct and the problem still exists, try turning your router off, waiting 30 seconds to a minute, then turning it back on. Let it set itself up again, this will usually take a minute or two, then try connecting your Wii to the internet again. If the problem continues, try altering your routers wireless channel setting. As most routers work on channel 6 by default, there could be interference. This process is different for each router.
Jul 13, 2011 | Nintendo Wii Console
I tri to connect internet error code 51330
Error code 51330 is trying to tell you that the Wii Wireless Adapter cannot connect to your wireless router. The most likely reason for this error is that the password you entered is not typed correctly, or that you forgot to type one in at all. Remember that security keys are always case sensitive.
Jul 01, 2011 | Nintendo Wii Console
Error code 51330
That's usually a problem related to wireless security. You'll want to try to make sure your computers can connect to the wireless--or see if it's working or not.
If everything is good. Make sure the password you have on your Wii to connect your console to the wifi is good.
That should work... if not, reset your wifi settings and try again!
Feb 08, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
