Question about Car Audio & Video
I'm connecting the Kenwood HDX-710. The problem I'm facing is that there's only 3 cables labelled out of the 7 in the power harness. ( Acc Illumi and Battery ). How do i connect the rest?
  • 1,940 Answers
This is directly from the manual, which is only available in Japanese, at least that I could find. Good luck!
Posted on Jul 13, 2010
Wiring diagram
rear battery wire connects to positive red terminal,then rear battery to negative black terminal,battery terminals facing inward,front battery to other batterys positive red cable ,wire labeled front battery to black negative cable,plug wire harness into quick disconnect...page 40 of owners manual
Oct 15, 2014 | Jet 3 Ultra Power Chair
How do i transfer itunes to kindle hdx by cable
Ok, if you have all your songs that you want on your kindle on your pc it is super easy to transferring them.
1.) Connect Kindle to PC using cable.
2.) Locate the Kindle, to do so go to My Computer -> Kindle (it might appear as MTP or just portable device)
3.) Open Internal Storage.
4.)Open Music folder and copy and paste your music straight to there.
5.) Enjoy it thoroughly!
Jan 24, 2014 | Amazon Kindle Fire HDX 7
IBR-WHCR2 wire harness extra yellow wire
The wire to which you refer applies power to the radio with the ignition switch in the ACC position and also maintains power flow to the memory when the radio is off. The proper connection should be apparaent from the installation instructions that came with your Metra adapter.
Dec 21, 2013 | Metra Car Stereo Wire Harness IBR WHCR2
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Kenwood DDX-514 label wires
90% of new and aftermarket harness' are the same, Red any Yellow are Constant 12v and ACC. 12v. Black is ground, Green is rear left speakers, Purple is the right rear. White is front left and Grey front right. Blue solid is Power Antenna, Blue with a white is an AMP Relay. (Which is another 12v ACC) You should have some sort of AV in/out lines for the rear screens, if that was an issue.
Jan 09, 2010 | Kenwood DDX-512 Car DVD Player
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Won't come out
1st you can try check position your dvd in your dashboard, if you did sure in good position and the body of dvd itsnot pressured by dashboard , check power connector , fuse of acc & bat+ beckup, make sure acc > 12v in stanby and work condition,bad conection power make voltage and ampere drop , so if dvd in heavy job acc drop from normal so make dvd mall fuction, other case if power normal that problem coused by broken mekanical of your display mekanic , Fix Ya
Sep 17, 2008 | Kenwood DNX7100 Car Video Player
The harness on the back of the head unit
with locking pin facing bottom of unit plugged in its
l to r top blank green blank yellow
l to r bottom blank blank black red
Dec 20, 2007 | Kenwood KVT-617DVD Car DVD Player
Car Audio & Video Logo
295 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
