Question about Whirlpool Duet GHW9150P Front Load Washer
Same problem i'm pretty much having the same problem as the people have mentioned on here and it says f 02.do you do what this means and what i could do to help it?the twice pause helps it to go off but it starts up and then just doesn't continue..its gets in some water and then just stops. thanks-amanda
  • 770 Answers
F/02 = Long Drain check the drain hose for kinks or check the electrical connections at the pump..Also check the filter for foreign objects(you need to remove the 3 screws in the lower panel ) twist open the filter and see what is stuck inside have a towel or 2 ready to catch the water ThenPress Pause/Cancel twice to clear fault
Posted on Apr 21, 2008
2003 honda civic o2 how to replace And how do i fin out which once is it
Hi Jesus, Im AL the owner of Big As Auto Repair.
If you have a 4 cylinder engine then you will only have two 02 sensors 1/1 is upstream and 1/2 is downstream. Upstream is the one closet to the engine and downstream is the one farther away from the engine.
If you have a six OR eight cylinder engine you will have four 02 Sensors. 1/1 means Bank One Sensor One. 1/1 and Bank one means right bank and right bank means the side with the number 1 spark plug. SO, 1/1 means, "Right Bank" Upstream 02 sensor. 1/2 means, "Right Bank" Downstream 02 sensor.
2/1 means, "Left Bank" Upstream 02 sensor and 2/2 means, "Left Bank" Downstream 02 sensor. Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
Nov 26, 2015 | 2003 Honda Civic
What does control panel error code mean #02-000 mean ?
Dear
The code mentioned for thermal related problem at fusser assy.
When the temp. achieved in fusser is bellow the defined temp.(normally 180'c) within 20 sec. this code display. This may be the defect due to the low voltage supply (bellow the rated voltage) or may loosen/open thermistor or may be main board(rare case).
thanks.
Nov 19, 2014 | Samsung CLP670ND - CLP-670ND Color Laser...
I have an unlocking code supplied by three for my nokia x3-02 mobile phone, how do I proceed with the unlocking?
Just you have mentioned your network is 3 . But, you didn't specify your country . To unlock your Nokia X3-02, use unlock code . You can get it from any of the online vendors like ProUnlocking.com to unlock your Nokia X3-02 .
Oct 07, 2014 | Cell Phones
I have An 02 hyundai xg350 and I'm trying to install an aftermarket CD player but somebody has cut the wiring adapter off so I don't know what wire goes whereso what are the wire colors
This site may help you The Install Doctor The Do It Yourself Car Stereo Installation Resource...
Not sure if you mean the plug is cut on the car or the radio. The colour code is pretty uniform , so its easy with a meter to identify permanent 12V, switched 12V and ground. Whats left will generally be speakers and aerial power lead if you have a power aerial.
Jul 22, 2014 | Cars & Trucks
What is the meaning of fault code. error 02. abnormal on my hitachi remote control for cooling unit rpc 5aq5-p
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
Jan 27, 2011 | Heating & Cooling
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
Sony DSR-1800
these errors mean the folowing:
02-291: failed to complete winding a tape.
02-275: detected T reel FG during threading.
02-696: Detected abnormal detectiion of S and T reel rotation during play and Rec.
The second and third faults indicate a fault with the board containing the driver for the reel motors. Unless you have the service manual i suggest you buy and replace the board.
It is the DR-428 board.
good luck
Luwangula
Apr 08, 2009 | Sony DSR-1800 DV/Mini DV VCR
I can unlock the brake from my 14" homelite chainsaw
Clarification Request
Posted by dontbother10 on Sep 05, 2009
Make? Model? What is the problem after you reset the brake? Lou
Posted by Kioat on Aug 19, 2009
What dor you mean unlock the brake? when you push the brake release forward?
Posted by youdoit on Aug 10, 2009
what is your problem? you are supposed to be able to unlock it if you can tell me what is up i may be able to help
Posted by obwhon on Jun 03, 2009
I'm glad you can unlock brake. It's pretty tiring pushing saw back and forth with brake locked.
Posted by obwhon on Jun 02, 2009
Do you mean you can't unlock the brake?
You must help us help you
Feb 27, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
