Question about Riccar Sewing Machines
Machine will not advance fabric. Feet move up and down but not front to back.
  • 5 more comments
  • jessnbarb Jul 13, 2010
    The stitch itself is fine. ONLY problem is the feet won't move the fabric thru. Feet DO move above the plate but are not pulling fabric toward back of machine.
    All these have been find automated suggestions, but to problems that I DON'T have. The ONLY problem is that the feet don't move in a front to back direction to pull the fabric through.
  • jessnbarb Jul 15, 2010
    OK, have tried solutions 1,2,3 to no avail. Now that I have gone thru the preliminaies, please address the specific problem I am having. Machine stitch is fine when I manually move fabric thru. Is there a fuse of might something have come loose inside the machine?
    Maybe I have used some incorrect terms because none of the solutions are addressing MY PROBLEM. I have the needle plate off and can see that the feed dogs are moving up and down but are not moving forward and backward. That is the ONLY problem.
    Solution 4 does NOT address my problem. What's next.
    Accept or Reject?... I REJECT. I have received Solution #4 about 4 times now and explained each time that it does NOT address my problem. I would like you to try ONE MORE TIME to find a reason for my problem. If the next solution is another generic automated one, I am done with FixYa.
  • jessnbarb Jul 16, 2010
    Re:Solution #5. I know how to adjust the stitch size. There is no front to back movement of feed dogs no matter what number the dial is set at.
  • 360 Answers
Hi, have you tried adjusting the tension as you sew?
Use a scrap piece of the same fabric, (doubled, etc to simulate piece you'll be working) and adjust the tension as you sew. Sometimes, that's all it takes.
Take care
Posted on Jul 16, 2010
    Guru:
  • 468 Answers
I am not an expert in Sweing machines but I have found a link for you wherein you can follow instruction to dismantle it. It seems that there might be some problem within the sweing machines that why the lever is not moving. I advice you to go to the below mentioned webiste:
http://www.riccar.com/ftp/whitepapers/1570-6950-bl2800-695.pdf
  • 532 Answers
If your machine does not advance,take the plate off of the feed dogs and check for lent and fuzz bliud up.
Take a can of dust off to blow the lent out of machine.
This will rectify the problem.
Thanks
Posted on Jul 15, 2010
  • 4,924 Answers
See that it has a button on the right side..the other than the one that sets the stem size...It is smaller and it is somewhere in the right side..usually ...That button ( spin-able ) controls the lower foot ..the one that actually drive the fabric front to back ....If this is set to 0 ..the under foot is not touching the fabric and it is not moving it ....just increase the value ...you will see after it behave ..how much ...usually at the half...
  • Catalin Turcu
    Catalin Turcu Jul 15, 2010
    by the way ..it may be not a button but a lever ..the issue is the same it is in the 0 position and it is not moving in the front to back ..but only at the spot ...when you increase the value on that button it will make the step bigger and move the fabric...
  • Catalin Turcu
    Catalin Turcu Jul 17, 2010
    I though yesterday that you did not understood that I wasn't refering on the stich lenght wheel (button ) but at the other one ..smaller that controls the feed dog ... anyway ..another thing crossed my mind...check ..maybe the lever or button that allows you to go forward and backward ...is stuck in the middle ...When it does that the fabric also will not advance...
  • 677 Answers
Here are a few solutions to check.
* Check your fabric to make sure it isn’t caught on something.
* Check your pressure foot to make sure it’s screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If it’s set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it’s securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you’ve been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
    Genius:
  • 1,040 Answers
there could be many reasons for the same. Personal examination will reveal the exact cause.. but here I am giving you two usual cause... (1) Have you tried adjusting the tension as you sew? Use a scrap piece of the same fabric, (doubled, etc to simulate piece you'll be working) and adjust the tension as you sew. Sometimes, that's all it takes.... (2) or the fabric forward mechanism has been stop functioning. there are many parts comes under this so personal examination will reveal the exact cause.. but still, some times little oiling can solve the problem...
Hope this has helped you.. Thanks...
Posted on Jul 13, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
Sir/Madom,
First of all Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate.
Correctly check and do Following-you will be Solved[Step by step]..
>Choose correct size needle for thread and fabric. >Properly insert needle. >Securely tighten needle clamp screw. >Use correct presser foot. >Reset presser foot. >Do not pull fabric, guide it gently.
>Decrease stitch length. >Replace needle. >Reset thread tension. >Increase pressure on presser foot. >Use underlay of tissue paper. >Upper thread and bobbin thread should be the same size and kind.
>Rethread machine. >Tighten upper thread tension. >Do not pull fabric; guide it gently. >Increase pressure on presser foot. >Reset presser foot. >Rewind bobbin.
>Securely install bobbin into bobbin case. >Correctly thread bobbin case. >Check to see that bobbin has been wound evenly. >Clean bobbin case and shuttle.
To Know Use Click here
Hope this Helps you...Thanks for Contacting FIxYa
  • shafi
    shafi Jul 13, 2010
    Which is your Model ...??
Try adjusting the tension as you sew. Use a scrap piece of the same fabric, (doubled up to simulate the piece you'll be working on) and adjust the tension as you sew.
http://www.patio-furniture-cushions.net/kenmore-sewing-machine-fabric-wont-move-gone-through-maunual-trying-to-fix-problem-difficulties-wtension
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
I want to free hand machine quilt - but it won't work when I drop the foot
You need an embroidery foot, that doesn't lay on the fabric like a normal foot and allows free motion of the fabric. If you are using one, be sure it is the appropriate foot for your machine and that you have pushed the appropriate button or place on your machine so that the machine will place the foot in the correct position.
Feb 16, 2017 | Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Quilting need to know if high, low or slant shank Also sew horizontoally or vertically. Ty
Here's a handy guide for presser feet:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Horizontal or vertical? A sewing machine generally sews from the front toward the back (the front being where you would sit). If you use the Reverse, then it would sew from back to front.
If you are darning or doing free motion quilting, you would first drop the feed dogs, attach a darning foot, and you would move the fabric by hand in any direction you choose.
Oct 15, 2015 | Kenmore Sewing Machines
Bottom feed stopped working, won't advance fabric, stopped all of a sudden
could you maybe while changing a bobbin or somehow , hit the Darning button its right next to the Bobbin release , a machine in darning mode wont advance the fabric and the traction feet go down to level with the platen (sign that it's in darning mode)
Aug 13, 2015 | Sewing Machines
The feet will not move the fabric.????
sorry but perhaps a trip to a sewing machine repair man is needed .
Aug 05, 2015 | Sewing Machines
There are different kinds of single needle foot, What are these?
If you take a look at this website you'll see the different feet for some makes
I assume you mean what are the different feet used for?
General purpose foot will have room for the needle to swing through wide stitches, but enough foot to hold the fabric and move it through against the feed dogs. This is the one you use most.
A straight stitch foot will have a little hole so that the needle only goes through a small area and the fabric can't move to give a neat plain straight stitch.
Plastic wide toe foot is good when you need to see what you are sewing onto such as applique (sewing a piece of fabric onto another with a wide satin stitch).
Teflon coated foot is good for slippery fabrics, it grips well.
A roller foot is great for textiles like leather and vinyl which don't feed nicely.
Then there are lots of feet for turning the fabric to sew it such as a rolled hem (these come in different widths so you can turn 2mm, 4mm or 6mm for example).
Felled foot (like the side seam on your jeans) joining two fabrics in a felled seam
Then there are feet for quilting and darning where you need to move the fabric smoothly in different directions, these will be small foot area and open stitching space usually.
Walking foot is a special one, part of the foot moves because a part of it clips around the needle bar and the up and down movement then activates the foot so its little teeth help to move the fabric from the top to supplement the normal feed dogs below. Pfaff machines actually built this function into their machines some years ago to give even feed from top and bottom. Great for quilting thick fabric sandwich or sewing together fabrics that want to slip or not feed smoothly.
There is also similar info here http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ which may help you to see the different uses and feet available.
Most manufacturers will sell their machine with 4 or 5 of the most used feet but often have more to buy aftermarket. And many feet between companies look very alike so if you have a clip on foot from one brand it may work on another machine with a clip on foot.
I hope that this is what you were asking.
May 26, 2011 | Sewing Machines
Brother XL-5130 machine...cannot get it to darn or embroidery work. I covered feed dogs with the plastic cover but cannot find a lever to put down the feet. With presser foot lever down (no feet and not...
You probably do not have lever to put the feed dogs down. That's why you have a cover. To free style embroider or darn you don't need a foot but the presser foot has to be down and as you run the machine, YOU will be doing the stitching by moving your fabric back and forth. This is usually done with a wooden embroidery hoop so that your fabric stays taught. I have done it on jeans without a hoop. Hope this helps.
May 18, 2010 | Brother XL-5130 Mechanical Sewing Machine
Fabric does not move forward
Either the presser foot does not have enough pressure on it or it is not lowering all the way to the fabric.
Remove the fabric.lower the presser foot.If the presser foot has no or little pressure look for the pressure regulator on top the machine or on the left side and see if you can make it tighter. Not all machines have this.Look to see if there is space between the foot and the teeth when you turn the handwheel. If there is space then the machine needs an adjustment.
sewman7
Apr 27, 2009 | PfaFF Hobby 4260
Sewing machine will not advance the fabric
Jan 27, 2009 | Sewing Machines
Sewing Machines Logo
137 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
