Question about HP DeskJet F380 All-In-One Printer
How many page can we print in black ink in F2400 hp all in one
  • 524 Answers
Hi
25 papers per one minute it can print
Posted on Jul 13, 2010
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Can you remove the battery from an hp F4480 printer to make it ignore incompatible cartridge message
Unfortunately, this does not work.
With respect to the HP 60 cartridge error message ("Incompatible Print Cartridges") and inability to print with your HP Deskjet F4480 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (which is typical of the 'incompatible error' alert). These same failures can (and randomly do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to A. and B), this will identify which ink cartridge is causing the issue:
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
            NOTE: To our team's knowledge there is no 'cartridge error bypass' method available for the HP Deskjet printer model. The cartridge will mostly likely need to be replaced with a new one.
            Please note that we provide professional ink cartridge refilling services in multiple countries:
            Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
            Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
            Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
            Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
            Fry's Electronics USA Ink Refill Service (34 stores): http://www.frys.com/ads/page51
            Best Buy Canada (4 stores) Refill Service: Downsview, Sherway, Toronto, & Vancouver (additional Toronto Best Buy stores opening in Fall 2014).
            Micro Center USA Refill Service (8+ stores): http://www.microcenter.com/site/content/refill-service.aspx
            We also have ink refilling centers in many University bookstores across the USA & Canada:
            Brigham Young University, Brigham Young University Bookstore - Idaho (BYU-I),
            Cornell University (CU), Kansas University (KU), New York University (NYU), San Diego State University (SDSU), University of San Diego (USD), University of Wisconsin - Madison,
            University of Virginia (UVA): http://www.cavaliercomputers.com/inkjetrefill.asp?
            Queens University (Kingston, Ontario, Canada) & University of Calgary (Calgary, Alberta, Canada)
            Refill Store Map Locator: http://www.go2ris.com/#findstore
            Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
            -Thank you
Jun 02, 2014 | HP F4480 All-In-One Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I have refilled my color and black cartridges and now I am getting "hp inkjet f2400 invalid cartridge".
Hi:
This is why manufactures suggest you do not use refill ink kits. Because the ink is not always compatiable with the printers, they are some times to thick and will overflow and cause errors. There are ink sensors on the cartridges to determine the kind of ink in the cartridge. Try using only the manufature ink cartridges to as much as possible.
May 31, 2011 | HP Printer Cartridges (Complete List): ,...
I have rectently replaced the inks, but it wont print the black parts, any solution?
If you are having issues on an HP officejet printer, go to the menu, click "Diagnostics," then print the "PQ Troubleshooting Pages." If black ink does not print, go to "Disable the Cartridge" and switch the magenta and black cartridges on the menu. Then, print the pages again. If black ink does not print, then the problem may be the toner cartridge.
http://printers.iyogi.net/hp/install-hp-...
Jan 23, 2011 | Office Equipment & Supplies
HP Photosmart C 4200 printer will not print in black. Will print all other colors
Try to  print a test page first. To print a test page press and hold the bottons power and cancel together. The test page will show you the amount of ink left in the cartridges.  If the black ink color bar is not visible in  the, than it will mean that the ink is low or depleted. Try a new genuine HP ink cartridge. It should help you.
Jan 26, 2009 | Office Equipment & Supplies
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
