Question about Kenmore Refrigerators
Check all circuts nothing is on (model #795.7834), does this refrig do a auto defrost and so do everything stop working even the water dispencer
  • 1,998 Answers
Is the light on on the inside of the machine if not then your machine is not getting power all fridges and freezers have an auto defrost cycle whether they be mechanicaly like the older ones or electronic like todays models defrost has nothing to do with you getting water to your door i dont actually think the power going to the unit is on if it is plz repost or send me a reply
thanks
Posted on Jul 13, 2010
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
My frigidaire gallery FRS26ZSH refrige side is not working but the freezer seems to be keeping things cold... the fan motor is running, is this a compressor problem? help
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 15, 2009 | Refrigerators
Refrigerator doesn't work but the top freezer does.
How to check stuff>
Sep 10, 2009 | Refrigerators
Our refrig.& freezer stoped working. i cleaned the coils and vacumed undernead. it worked all night and also made ice but it stoped working again this morning. so i pulled the back of and checked the...
Make sure the fan near the compressor is running and that the coils next to it are warm. If that's not the poblem
Then Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
Sep 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and water dispencer
Check the water inlet located at the back of the fridge.
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 21, 2009 | Whirlpool ED5FHEXMQ Side by Side...
The Jenn Air refrigerator (model JFC2089HEP) has two doors for the refrigerator and a freezer in drawer underneath. Inside the refrigerator unit is a button to pour cool, filtered water. It just stopped...
if your refrig. is still making ice it is not the water servo, or in other words the water inlet. it could be the touch button is corroded or one of the wires came off switch. if the water dispencer works some times and sometimes it dosent, it is the water servo or water inlet valve. this opens and closes the water valve when you press button to get water or when the ice tray needs to be filled up. my g.e. refrig. did the same thing. and this is what it was....hope this helps you......thanks eddy
Jan 03, 2009 | Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
