Question about Thermador CIT365EM Stainless Steel Electric Cooktop
Some of the burners are not getting hot can you help
  • 1,998 Answers
Hi ok first step is to remove the top plate so that you can get at the burners you would need to be able to use a multi meter and check each burner that you are getting power to each one if you dont have power going to the burner then it would be a wire or control problem if you do have power then you have a burner problem hope this helps plz if you are not electronicly inclined call a technician
Posted on Jul 13, 2010
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Burner stains Hot cookie sheet accidently set on
abrasive cooker cleaner. and pad. should clean it off. give it a good scrub.
Oct 27, 2013 | Kenmore Cooktops
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
One of the burners on my Jenn-Air electric cooktop does not turn on and get hot. 3 burners do work. Any suggestions?
the contact may be loose but most likely the burner needs to be replaced. the one you use the most usually goes first, and not getting hot enough is the common indicater of a shot burner
Jul 09, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Electric Burners Turn On, Off, On, Off
the burners are halagen they are supposed to work that way but dont use them without a pan on them to reflect the heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. DECU165 Electric Cooktop
Thermador CIT365EM Stainless Steel Electric Cooktop Logo
63 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
richie46
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
