I purchased an Optoma widescreen 16:10 enhanced projector 6 months ago. It was working fine till yesterday. When I plug it in the screen displays a pink background ( my presentation is green)any ideas how to fix it?
SOURCE: toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Posted on Aug 26, 2007
realbat2
  • 68 Answers
SOURCE: Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
Posted on May 12, 2009
  • 12 Answers
SOURCE: Multimedia projector display too pink
check the vga cable, usualy its a broken wire inside
Posted on May 18, 2009
SOURCE: My optoma hd65 projector worked fine for 2 months,
hi i am running a scart lead from my sky to my projector with a s-video lead going in the back of my projector but am only getting black and white picture!! can you help
Posted on Oct 04, 2009
projdoc
  • 2237 Answers
SOURCE: optoma projector
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Posted on Dec 02, 2009
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
I bought a usb-vga cable for my optoma widescreen 16:10 enhanced projector but its saying
hi sir,
try to switch the way of output, so that choice suitable screen output way.
certainly, it is possible with compatible problem. review your projector instruction, check it can support USB function or not by the manufacturer.
hope it is helpful for you.
regards,
Jack
flying200809@gmail.com
any friends who were looking for below products, welecome you to contact me,
Professional wholesaler and retailer: for below products
1) projector spare parts, such as color wheel, lamp, mother board,DMD. lens, etc.
2) computer mother board,
3) HP server, switch, router. Cisco router. switch etc. complete machine or asscessories or parts
4) server or router memory
5) GBIC OR SFP
Nov 29, 2011 | Optoma Office Equipment & Supplies
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
Optoma hd70: Power will not come on. Working fine till I took
Mark, I am having the same problem. I took my down to change the bulb, it was working fine before. Now I can't get it to do anything. Have you found a fix for it yet?
Mar 08, 2010 | Optoma HD70 DLP Projector
The optics are dusty in an Optoma HD32 projector, I require a service manual which would indicated the correct method to remove, clean and reinstall the optics.
go to http://www.tantht.blogspot.com/ . He has excellent instructions for dismantling an optoma projector. However I took it one step further. I still had a problem with overheating due to dust after I followed his steps twice. Then I also removed the back of the projector which gave me much better access to an internal fan. I could see a substancial amount of dust coming out when I blew compressed air through it this third time around. It has been working fine for 6 months since.
Jan 25, 2010 | Optoma HD70 DLP Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
Toshiba laptop won't work with new optoma projector
Aug 26, 2007 | Optoma Projector Multimedia Projector
242 people viewed this question
k24674
jasbo
jasbo
