Question about Radio Communications
Aerial replacement eu falcon
Is it a difficult job replacing the aerial?
  • 55 Answers
NOT AT ALL .....IF YOU ARE TALKING ABOUT A BASE STATION ANT.....FIRST GET A GOOD ANT ......GET THE MAST TO PUT IT ON ..1 OR 2 MAST.. YOU MAY WANT TO USE SOME GUIDE WIRES..IT'S A GOOD IDEA......MAKE SURE TO GROUND THE ANT..WITH A LIGHTING ROD THAT GOES INTO THE GROUND.....GET SOME BASE STATION COAX.........GET A SWR METER A CHEAP ONE FROM RADIO SHACK HOOK EVERY THING UP CHECK YOUR MATCH WITH THE METER AND YOUR GOOD TO GO........WHERE YOU PLACE THE ANT ON YOUR HOUSE WILL MAKE A
BIG
DIFFERENCE IN HOW THE ANT WILL PERFORM PICK UP A CB RADIO BOOK @THE LIBRARY OR LOOK INTO ONLINE
Posted on Feb 21, 2009
Where can i buy a replacement veon tv aerial port ?. to replace bent one
It will be difficult to get the body part of a tuner. You're asking about it. The Ariel socket is the part of its tuner. It will look like a small box [inside]; and should be replaced as whole unit. Contact any service technician. http://electronicshelponline.blogspot.com/
The part to replace will look like this.
Mar 24, 2015 | Televison & Video
Brake lights still not working just replaced brake swich,help
Have you checked for 12V at the bulb holders themselves? If 12V present, bulbs are bad or open ground at the light socket.
Aug 07, 2014 | Empire Comfort Systems E.F. Johnson BP196,...
Battery charge rate drops below 3.8volts thus after a few months after replacing the battery starting can be difficult
If your charging rate is too low, then check the connections and wires to your alternator. Replace alternator if necessary.
Nov 18, 2012 | Cars & Trucks
Aerial
Thought i would reply to your lonely thread. I had to replace the aerial on my last 159 as it was broken when i first got it, i replaced it with a bee sting type off0 ebay didnt cost much was worried it might be a bit rubbish but turned out to be pretty good. As far as i can remember i managed to remove the rear end of the head lining (below the aerial) by popping off the two poppers holding the headling to the roof i then managed to disconnect the cable that connects to the aerial and undo what i remember was one nut that connects to the aerial thread inside car. The job was fiddly but only because i did not want to remove the head lining any more than i had to. but not difficult. without head lining in way it really would be a two minute job.
Hope it helps
Parts Of Bmw.
May 30, 2012 | Volvo V40 Cars & Trucks
Peugeot 206 removal
Not a difficult job on this car try doing a renault twingo or modus ,what about the mercedes A class thing now thats a job and half ,Disconnect the battery and take your time its not a difficult job .
Feb 04, 2012 | Cars & Trucks
Hi can you tell me is it dificult to remove and replace the icc unit in a BA falcon ute. Is just a case of removing the four screws holding it in then pulling the whole panel out
Unfortunately NO. It needs a specialists to remove and replace that component. If you do it yourself you might ruin other components there without your knowledge. Take it to a specialist and have him do the job for you. Spending $5-$15 won't hurt to make this thing work.
Feb 02, 2011 | Falcon 4420
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
Replacing front wheel bearings
It isn't a particularly hard job but there are a few techniques that you need to know.
I wouldn't recommend you do it yourself but I would recommend you do it under supervision of someone who knows their stuff.
Retensioning the bearings correctly is extremely important.
Jun 27, 2009 | 1998 Ford Expedition
The Male end of my antenna cable broke off, and now i have no radio
YOU'LL HAVE TO REPLACE THE AERIAL BASE & AERIAL MAST UNFORTUNAETLY FOR THIS NOT TO BAD OF A JOB TO DO YOURSELF & PARTS ARE NOT TO EXPENSIVE TO PURCHASE.
Dec 30, 2008 | 2000 Volkswagen Beetle
Radio Communications Logo
98 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
