Tv is not coming on how do I reset to turn or get the power back on
  • 712 Answers
Is the t.v making any try to get on ? That is, do the t.v comes on for at least a fraction of second before it goes off ?
Posted on Jul 13, 2010
  • jeandaum Jul 13, 2010
    when I try to turn on the tv it blinks for about five second then goes off again.
  • Sebin Punnacheril
    Sebin Punnacheril Jul 13, 2010
    By ' BLINKS FOR ABOUT FIVE SECONDS' do you mean that it works fine for those 5 seconds. Also what were the earlier symptoms ? Had the t.v had a habit of turning off while watching, but not so often, that is works fine for some minutes and then turn off ?
How do i reset Clarity ctvl37w2hdf led tv or at least set the timer to off?
to reset the tv, hold the power button while you unplug the TV. Keep holding the power button for :15 seconds, then release it and turn the power back on. That should reset any timer.
Nov 25, 2014 | Hardware & Accessories
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
My tv wont come back on
Check the power cord to the television if you are unable to turn it on with the "Power" button on the front. Make sure the cord is connected properly to the television and to a working AC outlet. If a power outage has occurred, unplug the television for 30 minutes to allow it to reset and plug it back in.
Feb 01, 2013 | Sylvania LC-225SL9 22 in. LCD TV
I need to turn on&off the tv
1.) Unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
2.) Just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off.
Mar 03, 2011 | Insignia IS-LCDTV32 32 in. Television
Power went out and when it come back on the tv took a long time to start and the screen was verticle stripes (multi-color)
Check if the issue is with the TV by connecting any other device.
If the issue is with the TV, then try resetting the TV to the factory settings by performing the below steps:
To reset the TV, turn ON the TV, then while holding down the UP ARROW button on the Remote Control, press the Power button on the TV front panel.
The TV will turn OFF and then turn ON again. Then release the UP ARROW button to complete the reset procedure.
If the issue still persists, try Power resetting the TV.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
If the issue still persists, service is required for the TV.
Jul 12, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Stand by mode
How many times does the standby light flash...b/4 pausing and repeating ?
Dec 20, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
